IOx VM console
thock
Visitor
I am loading a VM on a C8300 platform using IOx.  I can load, activate, and run the VM but I cannot figure out how to access the console. The VM itself is configured for the standard console and a serial console (/dev/ttys0) and has qemu tools loaded. If I try to connect to the console, I get the following return:
Error processing command. Server returned  501
Any advice on how to enable the console?
balaji.bandi
if this configured as GRUB_CMDLINE_LINUX="console=tty0 console=ttyS0,115200n8" and connecting fails :
app-hosting connect appid <your_vm_app_id> console
then look below post  may help :
https://community.cisco.com/t5/edge-computing-infrastructure/ir1101-application-hosting-console-and-network/td-p/4196094
BB
M02@rt37
Hello @thock
Please share your IOS xe version and whether you deployed the VM as a VM application or an OCI container ?
Thanks.
Best regards
I am currently running IOS-XE 17.12.05a and I am installing my application as a VM with ioxclient version 1.18.0.0. The VM installs and runs but I don't have any console access.  I have /dev/ttyS0 configured as a serial console in the VM but it is not clear how to configure the package.yaml file to use it.
Maybe this is my problem... When I run ioxclient platform device getcfg I see the following in the output:
"console": {
  "enabled": false,
  "group_name": "libvirtd",
  "setup_script": "setupconsole.sh",
  "teardown_script": "teardownconsole.sh",
  "user_name": "appconsole"
Is there any way to enable this?
balaji.bandi
BB
