is it possible to change extension attribute in Cisco CUCM from CLI interface
shareifqubbaj
Hello
I would like to know if is it possible to change extension attribute in Cisco CUCM from CLI interface.
as example:  to lock extension or to change his class of service.
Thanks for your support
Sharif
amoherek
Hi Sharif,
If you are looking for a programmable way to update configuration settings in CUCM, I recommend using the AXL API.
The method you would be interested in is updateLine. Here is a link to AXL portal:
https://developer.cisco.com/site/axl/overview/
Here is a link to the schema reference:
https://developer.cisco.com/media/axl-schema-10-0/AXLSoap_UpdateLineReq.html#LinkE1B
Adrienne
