Jabber SDK in Node.js - Issue with Authentication
bclark001111111
Community Member
Here is the background before I get on to my help request:
I have a Call manager 10.5.1.10000-7 up and running. Jabber Server Licensed for 150 users installed and being used.
Task: I need to implement Jabber SDK on my web application that is being developed on MeteorJS/Node JS. I was able to implement the JQuery version of this. But i have an issue. The CUCM and User Authentication happens Manually from the local machine. I need this to happen at the Server level and as a background task on windows Login or least on Application Login. Can you please guide to some already implemented code in Node.Js or JQuery version.
Thanks in advance.
Ben Clark
Project Manager
Geevarghese Cheria
Hi Ben,
  Request to post your question under Jabber community and
for reference check this url - Re: Can we Use Jabber SDK for IM on a web server
Thanks and Regards,
Geevarghese
