Need API to fetch interfaces data of Access point.
deepikax
Please find attached screenshot of Interface data, can you please guide us to fetch the below data using API.
We are looking out for interfaces data of access point as per the attached screenshot, which consists of parameters like list of interfaces, admin status, operational status, protocols etc.
@deepikax cannot see your screenshot, it does not look like it has attached.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
deepikax
Updated the query with attachment.
Marcel Zehnder
Do you have a XE based WLAN controller in place (Cat98xx)?
If yes, your best option is RESTCONF (currently I don't have access to a WLC, but the below hopfully works... ...if not: Let me know):
curl  'https://WLC_IP/restconf/data/Cisco-IOS-XE-wireless-access-point-oper:access-point-oper-data/ethernet-if-stats' \
  -k \
  -u username:password \
  -H 'Accept: application/yang-data+json'
This endpoint contains the data you're looking for:
pyang -f tree Cisco-IOS-XE-wireless-access-point-oper.yang --tree-path /access-point-oper-data/ethernet-if-stats
module: Cisco-IOS-XE-wireless-access-point-oper
  +--ro access-point-oper-data
     +--ro ethernet-if-stats* [wtp-mac if-index]
        +--ro if-name?              string
        +--ro rx-pkts?              uint32
        +--ro tx-pkts?              uint32
        +--ro oper-status?          wireless-enum-types:oper-state
        +--ro rx-ucast-pkts?        uint32
        +--ro rx-non-ucast-pkts?    uint32
        +--ro tx-ucast-pkts?        uint32
        +--ro tx-non-ucast-pkts?    uint32
        +--ro duplex?               uint32
        +--ro link-speed?           uint32
        +--ro rx-total-bytes?       uint32
        +--ro tx-total-bytes?       uint32
        +--ro input-crc?            uint32
        +--ro input-aborts?         uint32
        +--ro input-errors?         uint32
        +--ro input-frames?         uint32
        +--ro input-overrun?        uint32
        +--ro input-drops?          uint32
        +--ro input-resource?       uint32
        +--ro unknown-protocol?     uint32
        +--ro runts?                uint32
        +--ro giants?               uint32
        +--ro throttle?             uint32
        +--ro resets?               uint32
        +--ro output-collision?     uint32
        +--ro output-no-buffer?     uint32
        +--ro output-resource?      uint32
        +--ro output-underrun?      uint32
        +--ro output-errors?        uint32
        +--ro output-total-drops?   uint32
        +--ro wtp-mac               yang:mac-address
        +--ro if-index              uint16
