SDWAN terraform
TahirAli12881
Frequent Visitor
Frequent Visitor
I have a device template with many variables. they look like this in the csv file
csv-deviceId,csv-deviceIP,csv-host-name,pnp_dhcp_defaultrouter_527,pnp_dhcp_network,/70/vpn70_internal_svc_Sec_if_name/interface/if-name,
is there a way to print out all the variables in a device template with terraform so that i can make the call correct?
i need to attach the template to a device like this
resource "sdwan_attach_feature_device_template" "branch" {
provider = sdwan
id = "9e6044a3-afdb-"
devices = [
id = "ISR4451-X/K9-FOC24"
variables = {
5 Replies 5
I do not think you can do this with TF, what you could do is create a local value in your TF config to hold the list of variables extracted from the CSV file you have, then use a file function to read the CSV file and parse it to extract the variable names. Finally, iterate through the extracted variable names and add them to the variables block in your sdwan_attach_feature_device_template resource.
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Thanks for ur reply. think I was not clear in explaining.
I need to know the name of the variables that Vmange will accept as key values.
Is there a way to get all these values somehow.
Because I need to build the terraform  resource with these vaules I belive.
No problem. The documentation does not explain the format and expected key names. Each Vmange service typically has dedicated documentation outlining available APIs, functionalities, and accepted parameters. Like for example I think the the vars in the example usage - https://registry.terraform.io/providers/CiscoDevNet/sdwan/latest/docs/guides/updating_templates
Required:
- `id` (String) Device ID
- `variables` (Map of String) Device variables
But i do not think you can pull all the variables sadly, much like the missing payload information in the docs. Hope this helps.
TahirAli12881
Frequent Visitor
Frequent Visitor
These are the variables as shown in the picture. all values with in () are the variables..
and this did work for me..Thanks
