SSO-HA -- idsClientLib-11.6.1 Secondary URI issue
itsubaidshahid
Trying to achieve SSO HA with IDS-client-lib, v11.6.1.
There are two IDS Urls configured in idsclientlib.conf file as shown in attachment below idsConfig.png
IDS1 = primaryServer -- IDS2 = secondaryServer
  1. If the primary server is up, On user request for SSO then it loads the configuration from config file and get the primary URL and perform SSO without any issue.
  2. If primary server is down then on user SSO action it should load the secondary server url on configuration load method, But this is not the case, everytime it loads just the primary Url.
So Due to this I am unable to achieve HA for SSO using idsClientLib v11.6.1.
Also added new configuration property in idsClientLib.conf,  i:e sso.mode=sso After adding this config property it starts giving new ids client exception as shown below.
ERROR 29308 --- [ost-startStop-1] c.c.c.c.i.c.i.IdSClientConfigurationImpl : Missing Parameters : [ids.resource.id]
ERROR 29308 --- [ost-startStop-1] c.c.c.c.i.c.i.IdSClientConfigurationImpl : Some of the mandatory parameters [ids.resource.id] are missing in the idsclientlib.conf
Any help will be appreciated !
Also from where the required list of configuration properties can be found ?
0 Replies 0
