tail-f NCS Python MAAPI Documentation
achenampara
Community Member
I'm trying to use the Python MAAPI to add a CSV list of "cisco-ios" devices to NCS. I am struggling to find documentation as to how to do this. Here is where I am stuck :
def addCiscoIOS(t, name, ipAddress):
24     ''' All Cisco IOS devices use device-type of CLI and port 22
25     This function will simply take row[0] and row[1] of the device_list csv (Name and IP)
26     and add it to NCS, to an existing authgroup (for now, xxxxxx)
27     '''
28     port = "22"
29     authgroup = "xxxxxx"
30     print( 'Adding CiscoIOS Device %s @ %s:%s authgroup: %s' % (name, ipAddress, port,authgroup))
31     path = '/ncs:devices/device{"' + name + '"}'
32     #print path
33     if (t.exists(path)):
34         #print t.keys(path)
35         print('Device [%s] exists skipping!' % (name))
36
39     else :
40       t.create(path)
41       print type(ipAddress)
42       t.set_elem(ipAddress, path + '/address')
43       _V1 = ncs.types.Value
44       vport = _V1(int(port), _V1.C_UINT16)
45       t.set_elem(vport, path + '/port/')
46       t.create(path + '/device-type/cli')
47       #_N = ncs.types.Value
48       #ned_type = _N('ned-id')
49       #t.set_elem(ned_type, path + '/device-type/cli/')
50       t.create(path + '/device-type/cli/{ned-id cisco-ios}') >>>> STUCK <<<<<<
51       #_V0 = ncs.types
52       #ios_device = _V0("cisco-ios", _V0.C_IDENTITYREF)
53       #t.set_elem('/ned-id/ cisco-ios', path + '/device-type/cli/')
54       _V = ncs.types.Value
55       venum = _V(1, _V.C_ENUM_HASH)
56       t.set_elem(venum, path + '/state/admin-state')
57       t.set_elem(authgroup, path + '/authgroup')
58
Geevarghese Cheria
Hi Ajay,
Request to post your question under ConfD User Community. Did you had any chance to check-Cisco DevNet: ConfD
Thanks and Regards,
Geevarghese
