The blueprint 'uccx-sandbox' is not published.
s-vangor
we use sandbox Catalog (cisco.com)> DevNet> Environments> Unified Contact Center Express 12.5
It is not available anymore and I just see error "The blueprint 'uccx-sandbox' is not published." when I try "Launch again".
Is it some temporary problem or something has changed in templates?
@s-vangor if there is no other solution in the sandbox you can you use you might check Cisco dcloud.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
@s-vangor looks like it was retired? https://community.cisco.com/t5/devnet-sandbox/upcoming-end-of-live-for-some-sandbox-labs/td-p/5126569
s-vangor
thank you for reply. Yes, it gone.
Does anybody know how to continue with CUCM and UCCX/Finesse integration development?
Hello @bigevilbeard , thank you for hint.
One of our account have possibility to start environment with UCCX in dCloud. It take again some time to use dCloud and be more familiar but at least we should be able continue in developmnet.
