WebDialer SSO Token
MMstre
Level 5
Level 5
We are attempting to integrate webdialer with a customer C# directory service. This service was previously integrated with an Avaya solution, now being migrated to Cisco.
Basically, we are looking to connect to CUCM to retrieve the user device information, then place a call using that device.
Since getProfileSoap is deprecated, we need to use getProfileDetailSoap.  When we use the user credentials, it works fine, however, due to requirements, we cannot pass this information, and the original application does not support collecting this information.
The other option is to use a token, but i am trying to figure out if there is a way to quickly retrieve the token without having to change much in the original directory application.
Any idea would be greatly apprecated
0 Replies 0
