colonsims
     I received my credentials and logged into to vpn.  I was able to telnet into all of the devices except the NxOS devices.  I even looked at the vrf routing table and those devices IPs are NOT present.
dist-rtr02#sh ip route vrf Mgmt-intf
Routing Table: Mgmt-intf
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, m - OMP
n - NAT, Ni - NAT inside, No - NAT outside, Nd - NAT DIA
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
H - NHRP, G - NHRP registered, g - NHRP registration summary
o - ODR, P - periodic downloaded static route, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is 10.10.20.254 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 10.10.20.254
10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 10.10.20.0/24 is directly connected, GigabitEthernet1
L 10.10.20.176/32 is directly connected, GigabitEthernet1
Anyone knows what's going on?
1 Comment
colonsims
I had to go through the Cisco Modeling Labs Server.  I got it to work.
