ACI and Kubernetes Lab -VPN Issue
aervacan
I reserved a lab but can't VPN to the lab.  Tried both OSX and Windows and getting the following error:
Log from  Mac (AnyConnect 4.5):
The secure gateway has rejected the connection attempt.  A new connection attempt to the same or another secure gateway is needed, which requires re-authentication.
The following message was received from the secure gateway: No assigned address
Log from Windows  (AnyConnect 4.4):
6/8/2018
     6:51:28 PM    Contacting 128.107.93.228:20340.
     6:51:35 PM    User credentials entered.
     6:51:37 PM    Establishing VPN session...
     6:51:37 PM    The AnyConnect Downloader is performing update checks...
     6:51:37 PM    Checking for profile updates...
     6:51:37 PM    Checking for product updates...
     6:51:37 PM    Checking for customization updates...
     6:51:37 PM    Performing any required updates...
     6:51:37 PM    The AnyConnect Downloader updates have been completed.
     6:51:38 PM    Establishing VPN session...
     6:51:38 PM    Establishing VPN - Initiating connection...
     6:51:40 PM    Disconnect in progress, please wait...
     6:51:40 PM    The secure gateway has rejected the connection attempt.  A new connection attempt to the same or another secure gateway is needed, which requires re-authentication.
     6:51:40 PM    AnyConnect was not able to establish a connection to the specified secure gateway. Please try connecting again.
     6:51:41 PM    Ready to connect.
admin11111
Level 4
Level 4
I can connect to the VPN, the creds for the APIC is not correct.
Hi Aaron, we had some issues with the VPN that were fixed over the weekend.  My credentials are working fine and I can access the APIC.
