04-09-2026 05:39 AM
Hi tehe team,
I've been working all morning with no issues pushing small changes to the simulator. I have not changed the credentials but now I only get the following error:
│ Error: Unable to authenticate. Please check your credentials
│ with data.aci_l3_domain_profile.nsxt_ext_domain,
│ on sources.tf line 9, in data "aci_l3_domain_profile" "nsxt_ext_domain":
│ 9: data "aci_l3_domain_profile" "nsxt_ext_domain" {
╵│ err: Unable to authenticate. Please check your credentials. Please report this issue to the provider developers.
With the same creds I can authenticate no issues to the WebUI.
Is there a reason for this?
Thanks for your help in advance.
Solved! Go to Solution.
04-09-2026 07:30 AM
It is working now. I didn't make any changes at all and retried after a couple of hours. I imagine the server was too congested.
04-09-2026 05:57 AM
Hi!
It looks like the issue might not be with your credentials themselves since you can log in via WebUI. A few things to check for Terraform/ACI provider authentication:
Session expiration / token issues – Sometimes API tokens or sessions expire even if the password hasn’t changed. Try refreshing your token or reinitializing the provider.
Provider version changes – Did the Terraform provider or your ACI module update recently? Certain versions may introduce stricter authentication checks.
Environment variables/config – Make sure the credentials used in Terraform are exactly the same as WebUI (no extra spaces, correct case, correct environment variable names).
API access permissions – WebUI login might work, but API access could be restricted if roles/permissions are changed.
If none of these work, reporting the issue to the provider developers as the error suggests is a good next step.
Has anyone else faced sudden Terraform ACI authentication failures despite working credentials?
04-09-2026 07:30 AM
