Ansible Problem with sandboxapicdc.cisco.com
fbarducci
I was trying to run some scripts with ansible on the sandboxapicdc.cisco.com apic but I have the following message:
TASK [Add Tenant] ****************************************************************************************************************
fatal: [sandboxapicdc.cisco.com]: FAILED! => {"changed": false, "msg": "Failed to connect to localhost at port 443: [Errno 111] Connection refused"}
Is it a wanted behavior or is there a procedure to follow in order to use ansible on the apic sandbox?
thank you
regards
hapresto
Take a look at these Learning Labs that walk through using Ansible for ACI.
Introduction to ACI and Ansible
Is any solution found?
fatal: [sandboxapicdc.cisco.com]: FAILED! => {"changed": false, "msg": "Connection failed for https://sandboxapicdc.cisco.com/api/aaaLogin.json. Request failed: <urlopen error unknown url type: https>"}
