anyconnect connectivity issues
salah ben hassouna
Community Member
Good Morning,
I have a problem with anyconnect I installed it but couldn't log into the lab using IP address devnetsandbox-usw1-reservation.cisco.com:20367
An error message is displayed "unable to contact devnetsandbox-usw1-reservation.cisco.com:20367 "
Best regards,
Couple of things you can check
  • Is the sandbox showing as active and up (no errors)
  • Do your company filter ports/destinations which might prevent access to sandbox
  • The IPv4 and IPv6 protocols could have been checked by default in your system after a system update or the Cisco AnyConnect application update.
  • Manually unselecting the IPv6 protocol resolves the client driver error in AnyConnect VPN
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
