AnyConnect Secure Mobility Client - Connection fails
guy.kouam1
I want to try the Collaboration 10.5 Lab. But I keep having followiind Issue with the AnyConnect Secure Mobility Client.
As mentioned in the Sandbox Lab documentation, I downloded an installed the AnyConnect Secure Mobility Client.
After receiving the confirmation Email that my Collaboration 10.5 Lab is ready, I  try to connect to the Lab using the Lab Network Address as mentionend in the Email.
But everytime I try, the Connection fails with following error  "Connection attempt failed. Please try again".
In The Message History I can see something like "No valid certificates available for authentication".
See Screenshot.
But as far as I can see, there is no possibility on this Client to configure a certificate. Am I wrong? Or is this a Bug?
Please help me.
We have noticed some compatibility with Anyconnect 4.0 and windows 8/8.1. We are currently investigating but we do know that Anyconnect 3.1 does work fine with Windows 8/8.1.
Can you uninstall Anyconnect 4.0 and install Anyconnect 3.1? Any variant of 3.1 is ok.
Joe
6 Replies 6
jokearns1
What version of Anyconnect  and what OS are you using?
Joe
Hi Joe,
I am working on Windows 8.1 Pro and I use following Anyconnect version: 4.0.00061. The full name of the installation-file is: "anyconnect-win-4.0.00061-pre-deploy-k9"
Guy
I'm having similar issue. I am running version 4.0.00061
thanks!
What OS are you using?
Joe
Joe
Hi Joe,
I tried the Version 3.1 of Anyconnect. It works!
Thanks a lot!
Guy
