@matthewoncisco
If you can conenct to the VPN, then check the services on the VMs. If they are not reachable at all, reboot them and try agian. Otherwise re-launch the lab.
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
