Can't Connect to Controller in "Secure DDoS Edge Protection with NCS"
Alexander Stevenson
After reserving the Secure DDoS Edge Protection with NCS sandbox and joining the VPN, we are unable to connect to the controller at http://10.10.20.51.nip.io/
Instructions:
Reality:
Also, the username for the NCS540 is wrong in the sandbox instructions page:
NCS 540 10.10.20.52 SSH demo/cisco123
The correct username is in the documentation but the overview page for this sandbox has the wrong username.
This sandbox is used with this Learning Lab: https://developer.cisco.com/learning/labs/secure-ddos-edge-protection-labs/reviewing-the-controller/
Ruben Cocheno
@Alexander Stevenson
i haven't tried that lab yet, but see the HTTP URL despite the fact of mentioning HTTPS. Perhaps worth a try? Otherwise top right corner to drop a messagae to the Dev team to assist you.
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
Alexander Stevenson
Thanks @Ruben Cocheno,
I've tried http and https on both Chrome and Edge browsers, with no luck.
zowu
the backend k3s certificate was expired. We've renewed the certificates and the controller is accessible now.
Alexander Stevenson
Thanks @ zowu, it works like a charm now
