Cat Center LAN Automation Issue
imayroam
Using the Catalyst Center with ISE lab, and i'm trying to run LAN automation.
I've provisioned and set SW1 as the seed device and LAN automation starts, but never finds any other devices (i defaulted Sw2)
I think this is because there's no routing to my LAN automation subnet from Cat Center?  I've been trying to find if there's a L3 device but i just cant find any documentation on that, or any 'what you can/cannot do' with this lab environment.  Must be able to run LAN automation and build a site/fabric surely?  I feel like i'm missing something.
Tried to get onto the devserver in the lab 10.10.20.20 but the page never loads, just to see if it had a default gateway
Any help/ideas as always appreciated.
Thanks.
Torbjørn
LAN Automation does not work with the Cat9kv yet AFAIK. You can set up a fabric but you won't be able to use LAN automation to provision the underlay.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
Torbjørn
