Catalyst Center always on lab
charliekay
Can i use POSTMAN on this?
Ruben Cocheno
@charliekay
Yes, but curl is also an option
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
Torbjørn
Yes, you can find the connection info under "instructions" for the lab. You can interact with the API as you would with any other DNAC/CC.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
Ruben Cocheno
@charliekay
You can use the pre-built collection here https://www.postman.com/ciscodevnet/workspace/cisco-devnet-s-public-workspace/collection/134222-1c960677-3882-492f-8075-a31449e3a47f
This should work right away with the sandbox.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
