Catalyst Center always on lab
globantt
How long the access last for this?
Ruben Cocheno
@globantt
The credentials remain the same as far i know, they might reset the lab from time to time to keep it clean
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
There is no time limit with always on sandboxes, the Cisco Catalyst Center Sandbox is accessed directly on the internet. VPN is not required.
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Ruben Cocheno
@globantt
