CI/CD pipeline for infrastructure automation missing Ansible
ZERONULL
Unable to use ansible for configuration management. When trying to launch ansible-playbook inventory.yml configure_multiple_vlans.yml from devbox sandbox it shows ansible:command not found. Same hapens with ansible --version. Is it missing ansible and I'am not allowed to install it on devbox sandbox environment or have I misunderstood something.
Torbjørn
Hello @ZERONULL,
Welcome to the community!
The development VM in this sandbox runs Gitlab CE(available on http://10.10.20.50) with Gitlab runner in containers so that you can test your CI/CD pipelines. Ansible is available inside the container that runs on the development VM, but not available to run on the VM itself. You should hence try to run your playbook from the Gitlab CI/CD
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
Torbjørn
Hello @ZERONULL,
