CML DevNet sandbox lab fails to start. Licensing issue?
NBenat
If try to start a from a CML Enterprise sandbox, I get "Starting lab failed. System is not licensed. I get a similar error when I try starting any node from any lab. I'm not sure this is a problem from my side. Any help is appreciated. Thank you
@NBenat I have let the ENG team know of this - thanks for reporting.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
7 Replies 7
It is working now. Looks like it was either some temporary issue or something was done to fix it. In any case, thank you for the prompt follow up.
@NBenat good stuff thanks for the update - ENG were able to swiftly turn this around!
@bigevilbeard hi dear,
I have the same issue. Can you please let ENG check it again?
I get this when I try to run my lab that I have uploaded and the same thing when I try to add a node from "ADD NODES" options.
Starting node failed: System is not licensed.
Thank you.
Hawbir
@hawbir Team is aware of an issue preventing lab set up - please check back later. Sorry for any inconvenience this may cause.
zowu
We've identified the root cause of the issue. The fixing may take up few hours.
Unfortunately, I still get the same message.
Hopefully, it will be fixed soon.
Thank you for your support.
Hawbir
