CML2.2.2 CSR1000V Subinterface Issue?
gmcdwllntwrk
Community Member
In CML2.2.2, I have one csr1000v interface connected to one iosvl2 interface.
On the router side, I've configured subinterfaces, and on the switch side, I've configured a trunk interface plus corresponding SVIs.  No ping.  My question:  Is there a known issue with subinterfaces on the csr1000v?
TIA.
2 Accepted Solutions
Hi @gmcdwllntwrk ,
This is due to the way the CSR1000v handles subinterfaces.
Please refer to the following post for more information on how to solve the issue.
https://community.cisco.com/t5/ipv6/ipv6-address-on-subinterfaces/td-p/4504574
gmcdwllntwrk
Community Member
Thanks So Much Harold,
Trying to get that port-channel working, I was questioning my insanity for a while there.
I wanted to model a connection to a trunk interface on the far side, so I did it like this, and it works.
Note: It may be a bit unusual to have a routing native vlan on the switch, but To everything, There is a season, and for every config, there is a reason...
RTR1 (CSR1000V)SW (IOSvL2)
! In lieu of a port-channel i/f! On this side a trunk w/ native VL 10
bridge-domain 10 vlan 10
bridge-domain 11 vlan 11
bridge-domain 12 vlan 12
interface GigabitEthernet1interface GigabitEthernet0/0
 no shut switchport trunk allowed vlan 10-12
 service instance 10 ethernet switchport trunk encapsulation dot1q
  encapsulation untagged switchport trunk native vlan 10
  bridge-domain 10 switchport mode trunk
 ! negotiation auto
 service instance 11 ethernet no shut
  encapsulation dot1q 11!
  bridge-domain 11interface Vlan10
 ! ip address 10.10.10.2 255.255.255.0
 service instance 12 ethernet no shut
  encapsulation dot1q 12!
  bridge-domain 12interface Vlan11
 ! ip address 11.11.11.2 255.255.255.0
! no shut
interface BDI10!
 ip address 10.10.10.1 255.255.255.0interface Vlan12
 no shut ip address 12.12.12.2 255.255.255.0
! no shut
interface BDI11!
 ip address 11.11.11.1 255.255.255.0
 encapsulation dot1Q 11
 no shut
interface BDI12
 ip address 12.12.12.1 255.255.255.0
 encapsulation dot1Q 12
 no shut
Hi @gmcdwllntwrk ,
gmcdwllntwrk
Community Member
 ! negotiation auto
! no shut
interface BDI10!
! no shut
interface BDI11!
 no shut
interface BDI12
 no shut
