Connection Error with IOS-XR Sandbox
maddiv
After connecting to Cisco VPN with the provided credentials, I have launched the SSH panel in the DevBox of the IOS-XR Sandbox
then I face the below error in accessing the remote URL
5 Replies 5
@maddiv i don’t use the guacamole console - are the devices reachable via the following ports on ssh?
IOS-XRv9000 R1
Username: admin
Password: admin
Management IP: 10.10.20.70
XR SSH Port: 2221
NETCONF Port: 8321
gRPC Port: 57021
XR-Bash SSH port: 2222
IOS-XRv9000 R2
Username: admin
Password: admin
XR SSH Port: 2231
NETCONF Port: 8331
gRPC Port: 57031
XR-Bash SSH port: 2232
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Thanks, devices is reachable only via the mentioned ports, but not via the ssh panel in the menu.
@maddiv can you use your terminal or ssh client to ssh to the devices? Trying to establish if the ssh access is broken or just via the tool.
Thanks!
Iam able to access the routers and the devbox using putty with the port details. I have a general query, is it possible to upgrade the routers with a specific IOS-XR software image provided by the user. can upgrades and downgrades possible?
@maddiv it is not recomended. If you wanted to use certain images, i would suggest looking at the CML sandbox as your testbed.
Hope this helps.
