Connection to Sanbox failure
Everytime I try to access a component of any sandbox I get a connection failure.
Mind that I am using the VPN connection installed through Cisco anyconnect, would you kindly help me?
The sandbox in question is the DevNet Sandbox CISCO SD-WAN 19.2, specifically the vmanage component.
Hello, in your screenshot you are attempting to connect the VPN to the vManage device via AnyConnect.
Once you have reserved your sandbox (SD-WAN in this case) you will get an email saying you have a reservation is set up, then a follow-up email with your VPN details for the sandbox. Here is a getting started guide https://developer.cisco.com/docs/sandbox/#!first-reservation-guide/hello-world
Once your VPN is connected, you can access the devices via standard protocols (HTTP/SSH). Please see the credentials for the devices in the Cisco SD-WAN Reservation Sandbox.
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Hope this helps.
