Differences in Archive Schema Between CUCM v11.0 and v11.5
arjunsocial
Level 4
Level 4
Is there any difference between the archive schema between CUCM versions 11.0 and and 11.5? I know for the archive service in 11.5 allows for an MS SQL Server DB. Would that also be the case for 11.0 and would the schema be the same?
arjunsocial
Level 4
Level 4
As a follow up here, it looks like PostgreSQL and Oracle are the only DBs available in 11.0, based on documentation here:
Database Setup for IM and Presence Service on Cisco Unified Communications Manager, Release 11.0(1) - External Database …
So the question still holds though. Would the schema be different between the external archive DB for 11 and 11.5?
Hi Arjun,
Please raise your DB schema related concerns within "DevNet Dev Support Questions" spark room. There are professional dev support guys in the room.
Please follow instructions on https://developer.cisco.com/site/spark-chat/  to join the room.
Bob
thank you!
