Firepower Management Center lab: how to connect to eStreamer service
jaapdkoning
Hi!
I started a Firepower Management Center sandbox with the hope of testing a eStreamer client application. But as far as I see there is only the HTTP UI/api available, and without an option to setup a VPN it is not possible to connect on other ports (the eStreamer TCP port 8302). As far as I see there are not other labs/sandboxes available that can provide this functionality.
I was confused because there supposedly was a lab available that was part of this integration to test eStreamer with Splunk through a VPN: https://github.com/CiscoDevNet/fmc-rest-api/blob/master/labs/firepower-estreamer-splunk/1.md
Any idea how to do this?
Best regards,
Jaap de Koning
Even on the VPN to the sandbox, inbound and outbound ports are limited. I see the repo is a number of years old and many changed would have taken place since that code was built, the repository has been archived also. So do not think this is now possible to test this function in this sandbox.
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
jaapdkoning
But is there a generic VPN capability available when none is specified in the Lab?
Well the fact that apparently it is not possible anymore is a sad conclusion but a valid one I guess ;). Thanks for the reply!
@jaapdkoning as far as i know, there is not.
