How to enable hardware-telemetry in Nexus9000 C93180YC-EX chassi
triloknallani
I am trying to enable feature hardware-telemetry but it is not allowing to enable. Any suggestions
Switch(config)# feature hardware-telemetry
% Invalid command at '^' marker.
M02@rt37
Hello @triloknallani,
What is your Firmware version?
Minimum for Hw Telemetry:
https://www.ciscolive.com/c/dam/r/ciscolive/emea/docs/2020/pdf/BRKDCN-2712.pdf
Best regards
NXOS variable = bootflash:/nxos.9.3.7.bin
Try enabling the Software Telemetry feature as this should be enabled before enabling Hardware Telemetry from what i recall.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
I have enabled software telemetry which is working fine and able to get data. While trying to enable hardware-telemetry it is not allowing
