Interface statistics API does not contain capacity percentage
raihanAbidin
Visitor
Have tried the API below and get response that include these statisctics rx/tx-packets, rx/tx-error etc. but not the up_capacity_percentage and down_capacity_percentage. Does vManage sandbox support those statistics? If yes, any pointer on which API to be used to get the capacity related statistics?
https://{{vmanage}}:{{port}}/dataservice/device/interface/stats?vpn-id=0&deviceId=10.10.1.17&af-type=ipv4
2 Accepted Solutions
@tanisha_sarraf @raihanAbidin i tested this on the reservable sd-wan sandbox here https://devnetsandbox.cisco.com/RM/Diagram/Index/c9679e49-6751-4f43-9bb4-9d7ee162b069?diagramType=Topology
https://{{vmanage}}:{{port}}/dataservice/statistics/interface
    "header": {
        "generatedOn": 1629715476012,
        "viewKeys": {
            "uniqueKey": [],
            "preferenceKey": "grid-raw_interfacestatistics"
        "columns": [
                "title": "Entry_time",
                "property": "entry_time",
                "displayFormat": "DD MMM YYYY h:mm:ss A z",
                "inputFormat": "unix-time",
                "dataType": "date"
                "title": "StatCycleTime",
                "property": "statcycletime",
                "dataType": "date"
                "title": "Device IP",
                "property": "vdevice_name",
                "hideable": true,
                "dataType": "string"
                "title": "Device Model",
                "property": "device_model",
                "display": "keyvalue",
                "keyvalueProperty": "deviceModel",
                "width": 120,
                "title": "Host name",
                "property": "host_name",
                "hideable": false,
                "title": "VPN Id",
                "property": "vpn_id",
                "dataType": "number"
                "title": "If name",
                "property": "interface",
                "title": "Rx packets",
                "property": "rx_pkts",
                "title": "Rx Octets",
                "property": "rx_octets",
                "title": "Rx Errors",
                "property": "rx_errors",
                "title": "Rx Drops",
                "property": "rx_drops",
                "title": "Rx packets per second",
                "property": "rx_pps",
                "title": "Rx kilo bits per second",
                "property": "rx_kbps",
                "title": "Tx Packets",
                "property": "tx_pkts",
                "title": "Tx Octets",
                "property": "tx_octets",
                "title": "Tx Errors",
                "property": "tx_errors",
                "title": "Tx Drops",
                "property": "tx_drops",
                "title": "Tx packets per second",
                "property": "tx_pps",
                "title": "Tx kilo bits per second",
                "property": "tx_kbps",
                "title": "Total mega bits per second",
                "property": "total_mbps",
                "dataType": "double"
                "title": "Oper Status",
                "property": "oper_status",
                "title": "Admin Status",
                "property": "admin_status",
                "title": "bw up",
                "property": "bw_up",
                "title": "bw down",
                "property": "bw_down",
                "title": "up capacity percentage",
                "property": "up_capacity_percentage",
                "title": "down_capacity_percentage",
                "property": "down_capacity_percentage",
                "title": "vnf_name",
                "property": "vnf_name",
                "title": "vip_time",
                "property": "vip_time",
                "dataType": "date"
                "title": "vnic_id",
                "property": "vnic_id",
                "title": "platform_type",
                "property": "platform_type",
                "title": "System Ip",
                "property": "system-ip",
        "fields": [
                "dataType": "date"
                "property": "vip_idx",
                "dataType": "date"
                "dataType": "string",
                "dataType": "date"
        "chart": {
            "xAxis": [
                "entry_time"
            "yAxis": [
                "rx_pkts",
                "rx_octets",
                "rx_errors",
                "rx_drops",
                "rx_pps",
                "rx_kbps",
                "tx_pkts",
                "tx_octets",
                "tx_errors",
                "tx_drops",
                "tx_pps",
                "tx_kbps"
            "series": [
                "interface"
            "title": "",
            "xAxisLabel": "Time",
            "yAxisLabel": "bytes"
    "data": [
            "down_capacity_percentage": 0,
            "tx_pps": 16,
            "total_mbps": 0.04,
            "device_model": "vedge-cloud",
            "rx_kbps": 20,
            "interface": "ge0/0",
            "tx_octets": 1617969,
            "oper_status": "Up",
            "rx_errors": 0,
            "bw_down": 0,
            "tx_pkts": 10096,
            "tx_errors": 0,
            "rx_octets": 1551547,
            "statcycletime": 1629715200028,
            "admin_status": "Up",
            "bw_up": 0,
            "interface_type": "physical",
            "tenant": "default",
            "entry_time": 1629714461255,
            "vip_time": 1629714461255,
            "af_type": "IPv4",
            "rx_pkts": 9703,
            "rx_pps": 16,
            "vmanage_system_ip": "10.10.1.17",
            "tx_drops": 0,
            "rx_drops": 0,
            "tx_kbps": 21,
            "vdevice_name": "10.10.1.17",
            "up_capacity_percentage": 0,
            "vip_idx": 6,
            "host_name": "site3-vedge01",
            "vpn_id": 0,
            "id": "AXtymHghYdW0CdV3u0qx"
            "tx_pps": 0,
            "total_mbps": 0,
            "rx_kbps": 0,
            "interface": "ge0/1",
            "tx_octets": 9534,
            "rx_errors": 0,
            "bw_down": 0,
            "tx_pkts": 147,
            "tx_errors": 0,
            "rx_octets": 57404,
            "statcycletime": 1629715200027,
            "bw_up": 0,
            "entry_time": 1629713894446,
            "vip_time": 1629713894446,
            "af_type": "IPv4",
            "rx_pkts": 401,
            "rx_pps": 0,
            "tx_drops": 0,
            "rx_drops": 120,
            "tx_kbps": 0,
            "vip_idx": 5,
            "vpn_id": 1,
            "id": "AXtymHghYdW0CdV3u0qw"
            "tx_pps": 0,
            "total_mbps": 0,
            "rx_kbps": 0,
            "interface": "system",
            "tx_octets": 0,
            "rx_errors": 0,
            "bw_down": 0,
            "tx_pkts": 0,
            "tx_errors": 0,
            "rx_octets": 0,
            "bw_up": 0,
            "interface_type": "logical",
            "entry_time": 1629713889009,
            "vip_time": 1629713889009,
            "af_type": "IPv4",
            "rx_pkts": 0,
            "rx_pps": 0,
            "tx_drops": 0,
            "rx_drops": 0,
            "tx_kbps": 0,
            "vip_idx": 4,
            "vpn_id": 0,
            "id": "AXtymHghYdW0CdV3u0qv"
            "tx_pps": 0,
            "total_mbps": 0,
            "rx_kbps": 5,
            "interface": "eth0",
            "tx_octets": 3944,
            "rx_errors": 0,
            "bw_down": 0,
            "tx_pkts": 70,
            "tx_errors": 0,
            "rx_octets": 481980,
            "bw_up": 0,
            "entry_time": 1629713873402,
            "vip_time": 1629713873402,
            "af_type": "IPv4",
            "rx_pkts": 2147,
            "rx_pps": 3,
            "tx_drops": 0,
            "rx_drops": 20,
            "tx_kbps": 0,
            "vip_idx": 3,
            "vpn_id": 512,
            "id": "AXtymHghYdW0CdV3u0qu"
            "tx_pps": 6,
            "total_mbps": 0.02,
            "rx_kbps": 10,
            "interface": "ge0/2",
            "tx_octets": 868948,
            "rx_errors": 0,
            "bw_down": 0,
            "tx_pkts": 4304,
            "tx_errors": 0,
            "rx_octets": 828040,
            "bw_up": 0,
            "entry_time": 1629713861294,
            "vip_time": 1629713861294,
            "af_type": "IPv4",
            "rx_pkts": 4377,
            "rx_pps": 6,
            "tx_drops": 0,
            "rx_drops": 0,
            "tx_kbps": 10,
            "vip_idx": 2,
            "vpn_id": 0,
            "id": "AXtymHghYdW0CdV3u0qt"
            "tx_pps": 11,
            "total_mbps": 0.05,
            "rx_kbps": 19,
            "tx_octets": 2545338,
            "rx_errors": 0,
            "bw_down": 0,
            "tx_pkts": 7553,
            "tx_errors": 0,
            "rx_octets": 1583306,
            "statcycletime": 1629715200014,
            "bw_up": 0,
            "entry_time": 1629713861253,
            "vip_time": 1629713861254,
            "af_type": "IPv4",
            "rx_pkts": 7006,
            "rx_pps": 10,
            "tx_drops": 0,
            "rx_drops": 1,
            "tx_kbps": 31,
            "vip_idx": 1,
            "vpn_id": 0,
            "id": "AXtymHghYdW0CdV3u0qs"
    "pageInfo": {
        "startTime": "1629714461255",
        "endTime": "1629713861253",
        "count": 6
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
The API has changed since this question was originally posted. You must now supply a query parameter which previously was not required for the /statistics/interface endpoint. If you use the GET method this must be supplied as a query-string and if you use a POST you must supply it in the request body. I prefer the POST version.
Here's an example I have tested using the always on sandbox using the example query from the API docs:
import requests
import json
base_url =  ""
username = ""
password = ""
# Get session cookie
payload = f"j_username={username}&j_password={password}"
headers = {
  'Content-Type': 'application/x-www-form-urlencoded',
response = requests.request("POST", base_url + "/j_security_check", headers=headers, data=payload, verify=False)
session_cookie = response.headers["set-cookie"]
# Get XSRF Token
headers = {
  'Content-Type': 'application/json',
  'Cookie': session_cookie
response = requests.request("GET", base_url + "/dataservice/client/token", headers=headers, verify=False)
xsrf_token = response.text
# Get interface statistics
payload = json.dumps({
  "query": {
    "condition": "AND",
    "rules": [
        "value": [
          "24"
        "field": "entry_time",
        "type": "date",
        "operator": "last_n_hours"
        "value": [
          "10.10.1.13"
        "field": "vdevice_name",
        "type": "string",
        "operator": "in"
headers = {
  'Cookie': session_cookie,
  'X-XSRF-TOKEN': xsrf_token,
response = requests.request("POST", base_url + "/dataservice/statistics/interface", headers=headers, data=payload, verify=False).json()
# "Pretty-print" response body
print(json.dumps(response.text,indent=2))
Note: This is not good code and should only be used as an example for how to query the API endpoint.
You can read more about the API endpoint here: https://developer.cisco.com/docs/sdwan/sd-wan-vmanage-v20-16/
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
15 Replies 15
Hello @raihanAbidin the sandbox support all the API resources within the design, ie if there is no cloud/onramp you cannot perform an API request for this. The ask on API is not clear, can you explain what you mean by up_capacity_percentage please? Does this refer to the interface state or bandwidth capacity of the interface? You might try
​/statistics​/interface​/ccapacity​/distribution
https://developer.cisco.com/docs/sdwan/#!reference-device-state-and-statistics
"data": [
"vdevice_name": "10.35.0.1",
"count": 143,
"interface": "GigabitEthernet2",
"min_up_capacity_percentage": 0.0099,
"bw_down": 1000000,
"max_up_capacity_percentage": 0.0099,
"bw_up": 1000000,
"avg_up_capacity_percentage": 0.0056034965034965035,
"max_down_capacity_percentage": 0.0063,
"min_down_capacity_percentage": 0.0063,
"avg_down_capacity_percentage": 0.004683916083916084,
"range": "0-25"
Hope this helps.
tanisha_sarraf
Community Member
Hi @bigevilbeard ,
We are looking for the API to get the data for below metrics:
"bw_down": 1000000,
"up_capacity_percentage": 0.0099,
"bw_up": 1000000,
"down_capacity_percentage": 0.0063,
We used the API shared by you:
still not getting data.
https://{{vmanage}}:{{port}}/dataservice/statistics/interface/ccapacity/distribution
    "header": {
        "generatedOn": 1629698529224,
        "columns": [],
        "fields": []
    "data": [],
    "distribution": {
        "50-75": 0,
        "0-25": 0,
        "75-100": 0,
        "uncategorized": 0,
        "25-50": 0,
        ">100": 0
Could you help me understand whether we need any configuration to be done on Cisco Vmanage?
@tanisha_sarraf based on this information the data points are all blank - is this a devnet sandbox you are testing or your own?
    "header": {
        "viewKeys": {
            "uniqueKey": [],
        "columns": [
                "dataType": "date"
                "dataType": "date"
                "hideable": true,
                "width": 120,
                "hideable": false,
                "title": "VPN Id",
                "title": "If name",
                "title": "bw up",
                "title": "bw down",
                "dataType": "date"
                "title": "vnic_id",
        "fields": [
                "dataType": "date"
                "dataType": "date"
                "dataType": "date"
        "chart": {
            "xAxis": [
                "entry_time"
            "yAxis": [
                "rx_pkts",
                "rx_octets",
                "rx_errors",
                "rx_drops",
                "rx_pps",
                "rx_kbps",
                "tx_pkts",
                "tx_octets",
                "tx_errors",
                "tx_drops",
                "tx_pps",
                "tx_kbps"
            "series": [
                "interface"
            "title": "",
    "data": [
            "tx_pps": 16,
            "total_mbps": 0.04,
            "rx_kbps": 20,
            "rx_errors": 0,
            "bw_down": 0,
            "tx_pkts": 10096,
            "tx_errors": 0,
            "bw_up": 0,
            "af_type": "IPv4",
            "rx_pkts": 9703,
            "rx_pps": 16,
            "tx_drops": 0,
            "rx_drops": 0,
            "tx_kbps": 21,
            "vip_idx": 6,
            "vpn_id": 0,
            "tx_pps": 0,
            "total_mbps": 0,
            "rx_kbps": 0,
            "tx_octets": 9534,
            "rx_errors": 0,
            "bw_down": 0,
            "tx_pkts": 147,
            "tx_errors": 0,
            "rx_octets": 57404,
            "bw_up": 0,
            "af_type": "IPv4",
            "rx_pkts": 401,
            "rx_pps": 0,
            "tx_drops": 0,
            "rx_drops": 120,
            "tx_kbps": 0,
            "vip_idx": 5,
            "vpn_id": 1,
            "tx_pps": 0,
            "total_mbps": 0,
            "rx_kbps": 0,
            "tx_octets": 0,
            "rx_errors": 0,
            "bw_down": 0,
            "tx_pkts": 0,
            "tx_errors": 0,
            "rx_octets": 0,
            "bw_up": 0,
            "af_type": "IPv4",
            "rx_pkts": 0,
            "rx_pps": 0,
            "tx_drops": 0,
            "rx_drops": 0,
            "tx_kbps": 0,
            "vip_idx": 4,
            "vpn_id": 0,
            "tx_pps": 0,
            "total_mbps": 0,
            "rx_kbps": 5,
            "tx_octets": 3944,
            "rx_errors": 0,
            "bw_down": 0,
            "tx_pkts": 70,
            "tx_errors": 0,
            "bw_up": 0,
            "af_type": "IPv4",
            "rx_pkts": 2147,
            "rx_pps": 3,
            "tx_drops": 0,
            "rx_drops": 20,
            "tx_kbps": 0,
            "vip_idx": 3,
            "vpn_id": 512,
            "tx_pps": 6,
            "total_mbps": 0.02,
            "rx_kbps": 10,
            "rx_errors": 0,
            "bw_down": 0,
            "tx_pkts": 4304,
            "tx_errors": 0,
            "bw_up": 0,
            "af_type": "IPv4",
            "rx_pkts": 4377,
            "rx_pps": 6,
            "tx_drops": 0,
            "rx_drops": 0,
            "tx_kbps": 10,
            "vip_idx": 2,
            "vpn_id": 0,
            "tx_pps": 11,
            "total_mbps": 0.05,
            "rx_kbps": 19,
            "rx_errors": 0,
            "bw_down": 0,
            "tx_pkts": 7553,
            "tx_errors": 0,
            "bw_up": 0,
            "af_type": "IPv4",
            "rx_pkts": 7006,
            "rx_pps": 10,
            "tx_drops": 0,
            "rx_drops": 1,
            "tx_kbps": 31,
            "vip_idx": 1,
            "vpn_id": 0,
    "pageInfo": {
        "count": 6
Thank you @bigevilbeard for your help! We managed to get the response now.
I get this error message when I send a GET to the API /dataservice/statistics/interface
Error:
    "errorMessage": "must not be null"
I'm using POSTMAN with the SD-WAN sandbox, and I'm able to make every other request with success, but not this one
Thansk
@Douglas Aguirre The error message "must not be null" indicates that a required field in your GET request to the Cisco SD-WAN API /dataservice/statistics/interface is missing. If you check the API documents (or the API docs on the device)
For example i would expect this to look like
https://vmanage-ip-address/dataservice/data/device/statistics/interfacestatistics?startDate=yyyy-mm-ddThh:mm:ss&endDate=yyyy-mm-ddThh:mm:ss
https://developer.cisco.com/docs/sdwan/20-4/#!sd-wan-vmanage-v20-4
You can see the following, the API documentation shows an example query string with two specific fields: "condition" and "aggregation". Ensure your query string includes these fields with the appropriate values.
query
string
(query)
Query string
Example : OrderedMap { "query": OrderedMap { "condition": "AND", "rules": List [ OrderedMap { "value": List [ "2020-05-10T01:00:00 UTC", "2020-05-10T01:30:00 UTC" ], "field": "entry_time", "type": "date", "operator": "between" } ] }, "aggregation": OrderedMap { "metrics": List [ OrderedMap { "property": "latency", "type": "avg" } ] } }
So an example would look like
## Query:
  "query": {
    "condition": "AND",
    "rules": [
            "value": [
                        "2020-10-20T10:00:00 UTC",
                        "2020-10-20T10:30:00 UTC"
            "type": "date",
## Sample Response
    "data": [
            "tx_pps": 0,
            "total_mbps": 0,
            "device_model": "vedge-CSR-1000v",
            "rx_kbps": 0,
            "interface": "Tunnel100001",
            "tx_octets": 0,
            "oper_status": "Down",
            "rx_errors": 0,
            "bw_down": 100,
            "tx_pkts": 0,
            "tx_errors": 0,
            "rx_octets": 0,
            "statcycletime": 1603190400016,
            "bw_up": 100,
            "entry_time": 1603189563640,
            "rx_pkts": 0,
            "af_type": "IPv4",
            "rx_pps": 0,
            "vmanage_system_ip": "1.1.1.6",
            "tx_drops": 0,
            "rx_drops": 0,
            "tx_kbps": 0,
            "vdevice_name": "1.1.1.6",
            "vip_idx": 16,
            "host_name": "BR2-CSR1000v",
            "vpn_id": 0,
            "id": "Ju2YRXUB6FA-Z7p5JO8f"
            "tx_pps": 0,
            "total_mbps": 0,
            "rx_kbps": 0,
            "interface": "Tunnel100002",
            "tx_octets": 0,
            "rx_errors": 0,
            "bw_down": 100,
            "tx_pkts": 0,
            "tx_errors": 0,
            "rx_octets": 0,
            "statcycletime": 1603190400017,
            "bw_up": 100,
            "rx_pkts": 0,
            "af_type": "IPv4",
            "rx_pps": 0,
            "tx_drops": 0,
            "rx_drops": 0,
            "tx_kbps": 0,
            "vip_idx": 17,
            "vpn_id": 0,
            "id": "J-2YRXUB6FA-Z7p5JO8f"
Hope this helps.
Thank youv @bigevilbeard
With your help I got the information I needed, but I am confused, isn't the API "dataservice/statistics/interface"? Where did this "/dataservice/data/device/statistics/interfacestatistics" come from?
Great news @Douglas Aguirre  it is listed on the doc here https://developer.cisco.com/docs/sdwan/20-4/#!bulk-api/request-parameters-1
Hi @bigevilbeard, I tried this but I am always getting this response from Postman. Any advice? TIA! 🙂
@Sors the API is expecting a required field in your request, but the field is either missing or set to null.
Hope this helps.
Hello @Sors,
Can you post the code/request you are using?
Sors
Community Member
Hi @Torbjørn thank you for your response! Here it is.
https://{{vmanage}}/dataservice/statistics/interface
import requests
import json
base_url =  ""
username = ""
password = ""
headers = {
# Get XSRF Token
headers = {
  "query": {
    "condition": "AND",
    "rules": [
        "value": [
          "24"
        "type": "date",
        "value": [
          "10.10.1.13"
        "type": "string",
        "operator": "in"
headers = {
