Issue in deploying Catalyst 9000 Always-On Sandbox -20251029T06335565
abbasjaber101
Hello team,
I've been facing an issue with deploying the always on cisco catalyst 9000 Always-on it takes a lot of time and then it shows an error saying in the resource tab error no asset found on the cisco XR always on I face the same issue what can I do as I have a final year project demonstration and I have to use these two machines to show case my project.
6 Replies 6
@abbasjaber101 the xr device, just copy the user details out of the instruction from the right side panel.
IOS XRv 9000 host	SSH port	NETCONF port	XR bash port	gRPC port	username	password
sandbox-iosxr-1.cisco.com	22	830	57722	57777	admin	C1sco12345
 I cannot spin up the catalyst 9000, i get a different error - team will need to advise here.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
I Know Cisco XR spins up but refuses any connection neither with Netconf on port 830 nor ssh on port 22 I used script on it and tried connecting using putty both cases the connection was refused.
@abbasjaber101 I see the xr device has the port 22 open, what do error do you get when trying to ssh to the device?
In putty I just get a black screen and refuses to connect massage in my script the same thing.
Jesus Illescas
@abbasjaber101 for now, the XR Always-On doesn't require you to launch a reservation. You can use it directly with what you find in the instructions. This might explain why you see the asset not found error.
This will change in the future; we are adding tacacs and once that is done, you will need to launch the reservation. We will publish here on the community once we deploy that change.
I just tested with iterm2 and VScode and I can ssh. I suspect this can be a problem with putty. can you try with other terminal client?
Jesus Illescas
I can see the C9K AO is respoding now. But at the moment there is a banner on the sandbox GUI that "ocassional 'active with error' labs" are happening. So try in a few hours.
