Issue starting IR1101 on CS-ES-USW1-E05
etmartel
I wanted to try the DevNet sandbox to run a IR1101 and it doesnt get to a point where I can log into it. I also get the 1st email telling me "We wanted to let you know that we are currently setting up your IR1101 - Industrial Routing and Edge Compute Lab.  ...". But the 2nd email never follows.
The issue happened on CS-ES-USW1-E05 here are the logs I got:
Error: Fatal Error Has Occurred
Description: A fatal error has occurred. Environment Driver cannot continue.
'OOB but type Default for 9.3 - USE THIS ONE' Sandbox command failed with 'Script runner exited with exit code: -1' error
Error: Script runner exited with exit code: -1
Description: No available Ids were found in: '1465'
DevBox-98b6719a: The selected resource driver does not contain 'GetInventory' function and is not valid for Auto Load
BTW: I also tried to reach out using the DevNet Sandbox Support Bot DEV.
Also I tried to start a 2nd time from scratch and got the same experience.
Thanks!
0 Replies 0
