Lost SSH connection to Switch after a reload command in Sandbox Lab NX-OS with Nexus 9Kv
WVR
hello,
When I have new Sandbox Lab NX-OS with Nexus 9Kv and I run the reload command, it seem I can't access the MNGMT port anymore.
Steps done:
- SSH to 172.16.30.103
nx-osv9000-3# reload
This command will reboot the system. (y/n)?  [n] y
Ping for more than 15 minutes from the Windows VMMaestro and it does not get back:
It feels that ending the current session and rebuilt is the only option.
This does not really seems to be a normal behaviour?
Thx,
Wim
It can take a few minutes( I normally time this by drinking two espressos YMMV) for the nodes to active/reachable.
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
8 Replies 8
Very odd, i haven't seen this. If you are using this sandbox which is built on virl. You can do the following from the jump host (10.10.20.20)
virl nodes
[find the node which was reloaded and did not come back]
virl stop [device name]
virl start [device name]
You can console into the device and also check its status
virl console [device name]
Hope this helps.
Hello @bigevilbeard,
Thanks for the info!
I'm afraid I'm not following. I've spinned up a new set, got to the 10.10.20.20 via SSH
Tried to add the virl nodes command when all 4 switches are still on to do a quick check.
The strange thing is, I don't have SSH access on the new created space. Maybe something else is going on?
I see, take a look at this thread here --> https://community.cisco.com/t5/devnet-sandbox/issue-with-open-nx-os-with-nexus-9kv-sandbox/m-p/3948370#M4081
Hope this helps.
Thx for the tip.
I might still do something wrong...
Done some more investigations...
I had issues to reach the VIRL with even a ping and I've turned it off and on again as the ping was negative...
After that I was able to get the status:
Hope this helps.
I was able to get them back to live! I've mad a nice cappuccino to kill the boot time!
That's awesome, plus you got the sandbox working! :p
