09-28-2023 04:19 PM
I am not able to login to VPN connection. Is there any way to verify the username and password through external portal?
09-28-2023 06:46 PM - edited 09-28-2023 06:47 PM
There are several reasons why a VPN may fail to connect, including:
Best regards
******* If This Helps, Please Rate *******
09-28-2023 09:15 PM
Thanks for possible issue summary. For me the VPN AnyConnect just say login fail. it does not notify that password or username not valid
09-28-2023 11:58 PM
In your reservation, VPN credentials can also be found by checking the "Output Window." Look for this button in your reservation:
This output button will toggle the output window open and closed. This window looks like a command terminal, and displays information about the sandbox automation, including VPN credentials once they've been generated.
I would type this and not copy/pasta this in the VPN client. If this does not work, cancel the reservation and generate a new one.
09-29-2023 01:13 PM
The command terminal is not accepting key input. I choose SD-WAN SandBox, Now, I see reservation is stopped.
Creation Time 9/28/2023 2:56:38 PM Start Time 9/28/2023 2:56:00 PM (Requires 15 min. setup) End Time 9/28/2023 7:01:00 PM Teardown Time 9/28/2023 6:56:00 PM Actual End Time 9/28/2023 7:01:04 PM Sandbox ID d633878b-52fd-4f75-b712-ac1478baa492 State Completed Domain DevNet
09-29-2023 04:21 PM
l would definitely end the reservation then and make a new one.
It may take some time for the original reservation to tear down. You can check the status of all your recent reservations here —> https://devnetsandbox.cisco.com/RM/Reservation/List
09-30-2023 01:04 AM
In which case your VPN would fail to connect as your reservation had expired. Suggest to start a new one.
Hope this helps
09-30-2023 01:24 AM
Best regards
