05-20-2022 02:56 AM
Hey Guys
i am trying to login into CML2 in SDWAN 20.4 SANDBOX LAB but i am unable to login i have tried multiple credentials like :admin/admin cisco/cisco cisco/Cisco developer/C1sco12345 but i am not able to login into CML2 IP in sandbox ip is https://10.10.20.161/ , earlier they have 19.x SDWAN lab in which i able to login into CML but i think in 20.4 SDWAN sandbx lab its not working , i have attached the snapshot for better view on issue , can anyone have the credentials help will be greatly appreciated !
05-20-2022 05:15 AM
Hello @MSayyed this is by design, since we moved to SD-WAN 20.4 version we only allow access to the devices in the SD-WAN fabric.
Hope this helps.
05-20-2022 06:07 AM
@bigevilbeard thanks for replay ..but in 19.x SDWAN sandbox lab earlier its was accessible yes i aware about recent maintenance activity , the reason i will asking because i just want play around with vEdges in topology by replacing either SITE1 &SITE2 cEdge lab or both & vice versa to get familiar with both platforms and command line, off course its sandbox environment everything will be erased after 8 hours but now i am not able to do so due to recent change ?
05-20-2022 06:14 AM
@MSayyed i understand, thank you for added details. The 19.2 is being removed from that catalog along with all 19.2 content as this point in time. When we built the 20.4 versions to replace the outdated 19.2, we removed access to CML as part of the updated security posture/policy. If you wanted to build/design your own SD-WAN fabric you would need do this in the CML sandbox.
Hope this helps.
