Open Connect and Sandbox Labs - Primeinfra and DNAC
Mikesisav
These two Sandboxes seem to be always on - primeinfra and dnac.
my openconnect vpn has xml response has no "auth" node and authentication error; cannot obtain cookie - prime infra.
dnac has this log : unexpected 404 result from server.
I am just trying to verify openconnect works.  How to tell the spin up time of sandbox without drilling into it?
They are very similar, however, devnet purely focuses on the API, IaC etc..
  • dCloud, a self-serving platform that you can use to learn about Cisco's latest products and solutions
  • DevNet Sandbox is for engineers, developers, network admins, architects, or anyone else who desires to develop/test against Cisco’s APIs, controllers, network gear, collaboration suite
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Hey there, with the 'always on' sandbox's you do not need a VPN. You can access these via your browser. API via Postman, Code etc..
Hope this helps.
It did help to know about always on verses reservation sandboxing.  thank you.
What is the difference between DCloud and this DevNetSandBox?
I am going back to school - DevNet High Class of 2020 - Go, Bobcats -  and this is there solution to openconnect and devsand box.
So, what is DCloud because it looks similar?  Is it another school that could potentially be our arch-rival?
Thanks, again, for your time.
Thank you for the clarity.
