Physical connectivity for Multi-IOS network sandbox
kaushik_gosar
I could not find the port connectivity details for the multi-network topology.
Can somebody please guide me.
Couple of ways, CDP, mac-address look up - or login into the VMMaestro  and look at the Topology.
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
For which devices are you looking for? Once connected via software VPN the you can access the lab's device and server via Telnet/SSH/HTTP. Details for this are located in the sidebar instructions of the sandbox. https://devnetsandbox.cisco.com/RM/Diagram/Index/6b023525-4e7f-4755-81ae-05ac500d464a?diagramType=Topology
Hope this helps.
Thanks for the reply.
I want to practice on the datacenter topology. I am able to SSH to the routers. But I need to know how the ports of each other router are connected to other routers. (Eg. Which port of core1 is connected to core2, etc.)
Without this info, how do I configure the IP addresses on the WAN interfaces ?
Please advise.
Hope this helps.
Thanks for the help and apologies for the delayed reply.
I was able to get the physical connectivity details by logging into the VIRL server using the VMMaestro credentials. But was unable to find the topology diagram anywhere.
Where exactly is the topology located when a user logs into the VIRL server ?
