01-20-2021 01:02 PM
I could not find the port connectivity details for the multi-network topology.
Can somebody please guide me.
Solved! Go to Solution.
01-21-2021 07:49 AM
Couple of ways, CDP, mac-address look up - or login into the VMMaestro and look at the Topology.
Hope this helps.
01-21-2021 04:25 AM
For which devices are you looking for? Once connected via software VPN the you can access the lab's device and server via Telnet/SSH/HTTP. Details for this are located in the sidebar instructions of the sandbox. https://devnetsandbox.cisco.com/RM/Diagram/Index/6b023525-4e7f-4755-81ae-05ac500d464a?diagramType=Topology
Hope this helps.
01-21-2021 06:10 AM
Thanks for the reply.
I want to practice on the datacenter topology. I am able to SSH to the routers. But I need to know how the ports of each other router are connected to other routers. (Eg. Which port of core1 is connected to core2, etc.)
Without this info, how do I configure the IP addresses on the WAN interfaces ?
Please advise.
01-21-2021 07:49 AM
Hope this helps.
02-07-2021 09:52 PM
Thanks for the help and apologies for the delayed reply.
I was able to get the physical connectivity details by logging into the VIRL server using the VMMaestro credentials. But was unable to find the topology diagram anywhere.
Where exactly is the topology located when a user logs into the VIRL server ?
