Problem with Sandbox (IOS XE on Catalyst 9000) Error: 'Setup' Blueprint command on 'IOS XE on Catalyst 9000' failed with 'General Execution' error
XS
I have tried twice to launch this sandbox this morning.
Whatever the sandbox is trying to do in the setup phase seems to fail: Ultimately I get the following message in the console and I don't get the email wit the VPN information.
The green button on the right (status button): Says "ACTIVE WITH ERRORS"
Any ideas?
Thanks in advance
6 Replies 6
XS
Ok looks like it's working now, someone must have fixed something in the back-end. Thanks guys
I have a simillar issue...
  'Setup' resource command on 'VIRL Server.NXOSV-008' failed with 'General Execution' error
       GWY-SJ-EXEC3 Execution Server:
and them
     'Setup' Blueprint command on 'Open NX-OS with Nexus 9Kv' failed with 'VM Provision Failure' error
     SJ-EXEC-01 Execution Server:
Any action I can take?
Hi Henrique,
Our execution servers experienced "offline" issues yesterday and it is recovered now. Could you please try your command again?
Bob
Do you know if there´s some problem today?
Gilmar
Similar problem today
'Setup' Blueprint command on 'Packaged Contact Center Enterprise' failed with 'VM Provision Failure' error
gjaimes
Level 5
Level 5
Same problem here,any clue?
thanks
Gilmar
