Problem with Site-to-site tunnel with IVT6 lab
dada
I finally have all information to create a tunnel with the IVT CUCM11 Lab, the tunnel looks like active, but I'm not able to contact the machines in the lab.
IPT-sandbox#ping 10.10.20.1
Sending 5, 100-byte ICMP Echos to 10.10.20.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
IPT-sandbox#show crypto isakmp sa
IPv4 Crypto ISAKMP SA
dst             src             state          conn-id status
64.103.26.60    XXX.XXX.XXX.XXX  QM_IDLE           2307 ACTIVE
IPv6 Crypto ISAKMP SA
IPT-sandbox#show crypto ipsec sa
interface: FastEthernet4
    Crypto map tag: FastEthernet4-head-0, local addr XXX.XXX.XXX.XXX
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (192.168.204.0/255.255.255.0/0/0)
   remote ident (addr/mask/prot/port): (10.10.0.0/255.255.0.0/0/0)
   current_peer 64.103.26.60 port 500
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 41, #pkts encrypt: 41, #pkts digest: 41
    #pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #send errors 0, #recv errors 0
This issue is resolved. Incorrect NAT statement on the ASA side.
Joe
10 Replies 10
jokearns1
Can you try the command "ping 10.10.20.1 source vlan1"
Joe
IPT-sandbox#ping 10.10.20.1 source vlan1
Packet sent with a source address of 192.168.204.254
And I try also with a laptop behind the router.
Do u wand i send you the conf?
Yes. Please attach it in here but remove the public IP, group/key entries and usernames
Joe
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2016.03.08 10:45:29 =~=~=~=~=~=~=~=~=~=~=~=
show run
Building configuration...
Current configuration : 6673 bytes
! Last configuration change at 08:13:21 UTC Tue Mar 8 2016 by XXXXXXXX
version 15.2
hostname IPT-sandbox
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
crypto pki trustpoint TP-self-signed-701638184
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-701638184
revocation-check none
--More--                            rsakeypair TP-self-signed-701638184
--More--                                 quit
ip cef
ip dhcp excluded-address 192.168.204.1 192.168.204.210
ip dhcp excluded-address 192.168.204.254
ip dhcp pool SDM-POOL
network 192.168.204.0 255.255.255.0
default-router 192.168.204.254
domain-name abc.inc
dns-server 10.10.10.1
option 150 ip 10.10.20.1
no ip domain lookup
ip domain name yourdomain.com
ip name-server 195.238.2.21
ip name-server 195.238.2.22
ip inspect udp idle-time 180
ip inspect tcp synwait-time 180
--More--                           ip inspect name FromExternal udp
ip inspect name FromExternal tcp
ip inspect name FromExternal icmp
ip inspect name FromExternal ftp
ip inspect name ToExternal udp
ip inspect name ToExternal tcp
ip inspect name ToExternal icmp
ip inspect name ToExternal ftp
no ipv6 cef
license udi pid C881W-E-K9 sn FCZ1838C1TQ
username XXXXXXXXXXX privilege 15 secret 5 $1$e
username XXXXXXXXXXX privilege 15 secret 5 $1$h
--More--                           crypto isakmp policy 2
encr 3des
authentication pre-share
group 2
crypto ipsec client ezvpn ivt
connect auto
group myTUNNEL key XXXXXXX
mode network-extension
peer 64.103.26.60
username XXXXXX password XXXXXXX
xauth userid mode local
--More--                           interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
description WAN
ip address XXX.XXX.XXX.XXX 255.255.255.240
ip access-group FromExternal in
ip access-group ToExternal out
ip nat outside
ip inspect FromExternal in
ip inspect ToExternal out
ip virtual-reassembly in
no ip route-cache cef
duplex auto
--More--                            speed auto
interface Virtual-Template1 type tunnel
no ip address
tunnel mode ipsec ipv4
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
no ip address
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered Vlan1
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 192.168.204.254 255.255.255.0
ip nat inside
ip tcp adjust-mss 1300
crypto ipsec client ezvpn ivt inside
--More--                           ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list NAT interface FastEthernet4 overload
ip nat inside source route-map EZVPN interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 XXX.XXX.XXX.XXX
ip access-list extended FromExternal
permit udp any any eq isakmp
permit tcp any any eq 4500
permit ahp any any
permit esp any any
permit gre any any
permit icmp any any
permit udp any any eq non500-isakmp
permit tcp host XXX.XXX.XXX.XXX host XXX.XXX.XXX.XXX eq 22
permit icmp host XXX.XXX.XXX.XXX host XXX.XXX.XXX.XXX
permit tcp host 64.103.37.6 host XXX.XXX.XXX.XXX
permit udp host 64.103.37.6 host XXX.XXX.XXX.XXX
--More--                            permit icmp host 64.103.37.6 host XXX.XXX.XXX.XXX
deny   ip any any log
ip access-list extended NAT
permit ip 192.168.125.0 0.0.0.255 any
ip access-list extended ToExternal
permit icmp any any log
permit ip any any
no cdp run
route-map EZVPN permit 10
match ip address 100
line con 0
login local
no modem enable
--More--                           line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
IPT-sandbox#
Is this your own router or was this sent out to you by one of the sandbox team?
Joe
Our own router, bought specially for Cisco sandbox Labs. I think it's the third at least.
I will be available in about 30 mins for a webex if you wish. There seems to be a lot of configuration on that router that we do not need. Can you get a console to it (or telnet) and you can share the screen on the call?
Joe
Hello Joe,
Ok, no pb for a webex.
I sent the webex details to your personal email. I am on the bridge now.
Joe
Joe
