RESTconf errors while changing interface parameters
DaleSchulz2814
I'm trying to run a script from the devnet python code samples and continue to get the following errrors while trying to modify an ip address on an interface:
What IP address do you want to set? 192.168.40.1
What Subnet Mask do you want to set? 255.255.255.0
"errors": {
"error": [
"error-message": "/if:interfaces/interface{Loopback100}/type: Runtime mapping error.",
"error-path": "/ietf-interfaces:interfaces/interface=Loopback100",
"error-tag": "malformed-message",
"error-type": "application"
Ending Interface Configuration
IP Address: 172.16.100.1 / 255.255.255.0
Any help in what I'm doing wrong?
2 Accepted Solutions
balaji.bandi
omz
Can you provide a link to the devnet code or lab you are working on?
Have a look here for some sample code that you can run on the sandbox.
https://github.com/CiscoDevNet/restconf-examples
10 Replies 10
balaji.bandi
Not sure how is your rights on the device and what device is this ?
here is example for rererence :
https://developer.cisco.com/docs/cisco-netconf-and-rest-device-management-api-documentation/#!cisco-netconf-and-rest-device-management-api-documentation/get-a-device-interface-configuration-using-netconf
BB
omz
I marked this open case as solved and closed so that your all not working on it and prioritizing anything here.  I was just trying to learn some new tech and there is plenty of other code to learn the same thing on all your sites.
Thanks for your help on a Sunday and stay safe during this virus problem
Dale
Hey Dale, I thought the issue was due to the sandbox being under maintenance yesterday. I see the same issue as you, however, I think this only works on interfaces other than loopback
(venv) STUACLAR-M-R6EU:restconf_update_ipaddress stuaclar$ python updateip.py
The router has the following interfaces:
  * GigabitEthernet1
  * GigabitEthernet2
  * GigabitEthernet3
  * Loopback5
  * Loopback22
  * Loopback72
  * Loopback100
  * Loopback103
  * Loopback678
  * Loopback1069
  * Loopback1245
  * Loopback1246
  * VirtualPortGroup0
Which Interface do you want to configure? GigabitEthernet3
GigabitEthernet3
Starting Interface Configuration
IP Address:  192.168.40.1 / 255.255.255.0
What IP address do you want to set? 192.168.50.1
IP Address:  192.168.50.1 / 255.255.255.0
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Wow! I'm flattered that the man, the myth, the "big evil beard responded to my open ticket!!😎 (I actually follow you and hpresto on twitter).
Actually no worries, there's lots of tools Cisco has out there to learn REST. I just jumped to a different lab.
Stay home and keep you and your family safe!
Dale
Thanks, buddy, the money is in the mail. :p
hello bigevilbeard
can you please share the link for this lab?
thank you
Sure Omar, i am not sure if this is learning lab - I know the repo from while back https://github.com/CiscoDevNet/python_code_samples_network
He's correct that it does work with a physical interface and not with a loopback though!
thank you! :)
