Showing results forĀ
Search instead forĀ
Did you mean:Ā
Sandbox Specific Technical Issues
tikshoret
the ise in this lab doesnt communicate with the switches (default config on the switch, i didnt change anything)
i open the cml and do ping fromsw1  g0/0 vrf Mgmt-vrf to catalist center 10.10.20.85 its work
when i ping to ise 10.10.20.25 doent work and dosent see mac in the arp table for 10.10.20.25
its seem they are on they same subnet
but the ise doent have connectivety to the switches
somebody know whats wrong?
jokearns1
Hi @tikshoret
Fastest thing to do is kill your current reservation and spin up a new one. If the problem persists, we can troubleshoot.
Joe
do you mean to closed the lab and order a new one
because i did it and the problem  its the same
ecorban
hi tikshoret,
dnac talks to nodes via snmp. dnac talks to ise via pxgrid. u need to make sure px grid is available. if not then u need to re-establish trust via ise and dnac which works ok. ise can be configured to talk to the nodes via radius. we can look to configure ping for u if its needed for ur work, but right now is an issue. we can look to this after the holiday break.
