SD-WAN 20.10 AlwaysOn Authentication Issues
ckodadek
Could someone please reset the devnetuser/password on SD-WAN 20.10 AlwaysOn?
It's complaining that the user is locked and/or expired at the login screen, and API authentications are failing as well.
It could be too many attempts have been made in a short period and the account is now locked, this happens sadly on always on sandboxes, suggest to switch to the reservable version until this is cleared.
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Hope this helps.
