UCCX Sandbox - Jabber connection problem
connor.sadler
I've been trying to show a colleague the UCCX Sandbox today.
This was all working a few days ago.
Today I get an error when I've logged into Jabber:  Unable to connect   CJ:109:3
Please see attachmented images for more details.
It appears from a quick Google that there may be something wrong with the "End user" configuration.
I found that screen in the web browser admin console but didn't know what to change.
Can you advise please?
Connor
jacoadam
Level 5
Level 5
Hello Connor-
Thanks for your reply! I can check on this device shortly! It looks the jabber phone (CSFD) isn't able to register. First try clicking the phone icon in the lower left corner and selecting "Use my computer to make calls" if you haven't tried that already.
Secondly, could you see if you can replicate the error on another agent? Try Agent002@abc.inc with password ciscopsdt.
Note: If you set your primary DNS to 10.10.20.100 you can resolve all lab DNS records and login using the service record.
I will take a look at your lab shortly.
Thanks!
Jacob
Hi Jacob,
That was quick, thanks!
I did try that "Use my computer to make calls" - didn't make any difference
I also tried it on a second machine - a virtual machine with Jabber installed - with Agent002 and got the same problem
They both have the same version of Jabber I believe, not sure if that is the issue.
The sandbox reservation was ending but I just extended it
Connor
Hey Connor-
I found the issue. The lab you are using had some old servers in it that have a non-standard configuration. The best course of action is to end your current reservation and make a new one, which will have the UCCX servers with the current configuration. Apologies for the mix-up.
Thanks!
Jacob
Thanks Jacob, it has worked fine today
