cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
9
Respuestas
Downgrade Router Cisco 43
colcha
Beginner
Beginner
Good Mornig Community ,
My new cisco 4321 router comes with software version isr4300-universalk9.17.03.04a.SPA.bin.
By standard in my project all routers must have software version isr4300-universalk9.16.09.04.SPA.bin.
When downgrading the software from isr4300-universalk9.17.03.04a.SPA.bin. to isr4300-universalk9.16.09.04.SPA.bin. , there is a license problem .
Does that mean I have to apply for a new license?
Sorry for the question, maybe it's a basic question, but I prefer to ask it here in the community and I thank you in advance for your help
Best Regards ,
Anibal
9 RESPUESTAS 9
M02@rt37
Advocate
Advocate
Hello @colcha,
what is the problem exactly? Have you got error message?
Please share output.
Best regards
******* If This Helps, Please Rate *******
Ben
Hi @colcha
 Depending on how did you activate your license before downgrade, you need to repeate the process now with the new IOS.
For example
Device#license install bootflash:FDO203520HU_201804090203446350.lic
Hi Flavio ,
Okay
colcha
Beginner
Beginner
Hi M02@rt37
Initializing Hardware ...
Located isr4300-universalk9.16.09.04.SPA.bin
Package header rev 3 structure detected
IsoSize = 554385408
Performing Integrity Check ...
Performing Signature Verification ...
RSA Signed RELEASE Image Signature Verification Successful.
Image validated
%IOSXEBOOT-4-BOOT_SRC: (rp/0): WARNING: Attempting to use bootflash for packages storage!
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software [Fuji], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.9.4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Thu 22-Aug-19 18:09 by mcpre
PLEASE READ THE FOLLOWING TERMS CAREFULLY. INSTALLING THE LICENSE OR
LICENSE KEY PROVIDED FOR ANY CISCO SOFTWARE PRODUCT, PRODUCT FEATURE,
AND/OR SUBSEQUENTLY PROVIDED SOFTWARE FEATURES (COLLECTIVELY, THE
"SOFTWARE"), AND/OR USING SUCH SOFTWARE CONSTITUTES YOUR FULL
ACCEPTANCE OF THE FOLLOWING TERMS. YOU MUST NOT PROCEED FURTHER IF YOU
ARE NOT WILLING TO BE BOUND BY ALL THE TERMS SET FORTH HEREIN.
Your use of the Software is subject to the Cisco End User License Agreement
(EULA) and any relevant supplemental terms (SEULA) found at
http://www.cisco.com/c/en/us/about/legal/cloud-and-software/software-terms.html.
You hereby acknowledge and agree that certain Software and/or features are
licensed for a particular term, that the license to such Software and/or
features is valid only for the applicable term and that such Software and/or
features may be shut down or otherwise terminated by Cisco after expiration
of the applicable license term (e.g., 90-day trial period). Cisco reserves
the right to terminate any such Software feature electronically or by any
other means available. While Cisco may provide alerts, it is your sole
responsibility to monitor your usage of any such term Software feature to
ensure that your systems and networks are prepared for a shutdown of the
Software feature.
cisco ISR4331/K9 (1RU) processor with 1784318K/6147K bytes of memory.
Processor board ID FDO264XXXXXX
1 Ethernet interface
3 Gigabit Ethernet interfaces
1 ATM interface
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3207167K bytes of flash memory at bootflash:.
0K bytes of WebUI ODM Files at webui:.
%INIT: waited 0 seconds for NVRAM to be available
card type e1 0 1
% Invalid input detected at '^' marker.
isdn switch-type primary-net5
WARNING: Command has been added to the configuration using a type 5 password. However, type 5 passwords will soon be deprecated. Migrate to a supported password type
controller E1 0/1/0
clock source network
pri-group timeslots 1-31
controller E1 0/1/1
controller E1 0/1/2
controller E1 0/1/3
SETUP: new interface Service-Engine0/4/0 placed in "shutdown" state
Press RETURN to get started!
*Jul 27 11:39:29.555: %SMART_LIC-6-EXPORT_CONTROLLED: Usage of export controlled features is not allowed
*Jul 27 11:39:30.375: %LICENSE-6-EULA_ACCEPT_ALL: The Right to Use End User License Agreement is accepted
*Jul 27 11:39:30.440: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = esg Next reboot level = uck9 and License = uck9
*Jul 27 11:39:30.489: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = esg Next reboot level = securityk9 and License = securityk9
*Jul 27 11:39:30.491: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = esg Next reboot level = ipbasek9 and License = No valid license found
*Jul 27 11:39:31.051: %ISR_THROUGHPUT-6-LEVEL: Throughput level has been set to 100000 kbps
*Jul 27 11:39:34.031: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Jul 27 11:39:40.128: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Jul 27 11:39:40.648: %VOICE_HA-7-STATUS: CUBE HA-supported platform detected.
*Jul 27 11:39:43.600: %LINK-3-UPDOWN: Interface Lsmpi0, changed state to up
*Jul 27 11:39:43.611: %LINK-3-UPDOWN: Interface EOBC0, changed state to up
*Jul 27 11:39:43.611: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
*Jul 27 11:39:43.613: %LINEPROTO-5-UPDOWN: Line protocol on Interface LI-Null0, changed state to up
*Jul 27 11:39:43.614: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to down
*Jul 27 11:39:43.629: %IOSXE_RP_ALARM-6-INFO: ASSERT CRITICAL GigabitEthernet0 Physical Port Link Down
*Jul 27 11:39:43.629: %LINK-3-UPDOWN: Interface LIIN0, changed state to up
*Jul 27 11:39:45.519: %IOSXE_MGMTVRF-6-CREATE_SUCCESS_INFO: Management vrf Mgmt-intf created with ID 1, ipv4 table-id 0x1, ipv6 table-id 0x1E000001
*Jul 27 11:39:45.572: %LINEPROTO-5-UPDOWN: Line protocol on Interface Lsmpi0, changed state to up
*Jul 27 11:39:45.573: %LINEPROTO-5-UPDOWN: Line protocol on Interface EOBC0, changed state to up
*Jul 27 11:39:45.573: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Jul 27 11:39:45.573: %LINEPROTO-5-UPDOWN: Line protocol on Interface LIIN0, changed state to up
*Jul 27 11:38:27.156: %CMRP_PFU-6-FANASSY_INSERTED: R0/0: cmand: Fan Assembly is inserted.
*Jul 27 11:38:27.156: %CMRP-3-PFU_INITIALIZATION: R0/0: cmand: The RP has failed to initialize a Power Supply/Fan module controller because the idprom is empty for slot 2
*Jul 27 11:39:34.281: %CMLIB-6-THROUGHPUT_VALUE: R0/0: cmand: Throughput license found, throughput set to 100000 kbps
*Jul 27 11:39:46.495: %ONEP_BASE-6-SS_ENABLED: ONEP: Service set Base was enabled by Default
*Jul 27 11:39:47.984: %SYS-2-PRIVCFG_DECRYPT: Successfully apply the private config file
000027: *Jul 27 11:39:48.049: %SYS-6-CLOCKUPDATE: System clock has been updated from 11:39:48 UTC Thu Jul 27 2023 to 12:39:48 CET Thu Jul 27 2023, configured from console by vty0.
000028: *Jul 27 11:39:48.051: %SYS-6-CLOCKUPDATE: System clock has been updated from 12:39:48 CET Thu Jul 27 2023 to 13:39:48 CEST Thu Jul 27 2023, configured from console by vty0.
000029: *Jul 27 11:39:48.272: %AAAA-4-CLI_DEPRECATED: WARNING: Command has been added to the configuration using a type 5 password. However, type 5 passwords will soon be deprecated. Migrate to a supported password typeenabling sss event trace
000030: *Jul 27 11:39:49.540: %SYS-5-CONFIG_I: Configured from memory by console
000031: *Jul 27 11:39:49.550: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/0, interfaces disabled
000032: *Jul 27 11:39:49.550: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/1, interfaces disabled
000033: *Jul 27 11:39:49.551: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/2, interfaces disabled
000034: *Jul 27 11:39:49.551: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/4, interfaces disabled
000035: *Jul 27 11:39:49.557: %SPA_OIR-6-OFFLINECARD: SPA (ISR4331-3x1GE) offline in subslot 0/0
000036: *Jul 27 11:39:49.557: %SPA_OIR-6-OFFLINECARD: SPA (NIM-4MFT-T1/E1) offline in subslot 0/1
000037: *Jul 27 11:39:49.561: %SPA_OIR-6-OFFLINECARD: SPA (NIM-VA-B) offline in subslot 0/2
000038: *Jul 27 11:39:49.565: %SPA_OIR-6-OFFLINECARD: SPA (PVDM4-128) offline in subslot 0/4
000039: *Jul 27 11:39:49.808: %IOSXE_OIR-6-INSCARD: Card (fp) inserted in slot F0
000040: *Jul 27 11:39:49.808: %IOSXE_OIR-6-ONLINECARD: Card (fp) online in slot F0
000041: *Jul 27 11:39:49.896: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 0
000042: *Jul 27 11:39:49.896: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 0
000043: *Jul 27 11:39:49.936: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 1
000044: *Jul 27 11:39:49.936: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 1
000045: *Jul 27 11:39:50.064: %IOSXE_OIR-6-INSSPA: SPA inserted in subslot 0/0
000046: *Jul 27 11:39:50.068: %IOSXE_OIR-6-INSSPA: SPA inserted in subslot 0/1
000047: *Jul 27 11:39:50.069: %IOSXE_OIR-6-INSSPA: SPA inserted in subslot 0/2
000048: *Jul 27 11:39:50.070: %IOSXE_OIR-6-INSSPA: SPA inserted in subslot 0/4
000049: *Jul 27 11:39:52.430: %SYS-5-RESTART: System restarted --
000050: *Jul 27 11:39:52.503: %HA_EM-6-LOG: dialtone: Re-Asserting Custom DIAL_TONE2 for DE
000051: *Jul 27 11:39:52.568: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
000052: *Jul 27 11:39:52.578: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
000053: *Jul 27 11:39:52.634: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to up
000054: *Jul 27 11:39:52.634: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
000055: *Jul 27 11:39:52.946: %HA_EM-6-LOG: dialtone: Custom dialtone2 for DE configured
000056: *Jul 27 11:39:57.849: %SPA_OIR-6-ONLINECARD: SPA (ISR4331-3x1GE) online in subslot 0/0
000057: *Jul 27 11:39:59.708: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Startup Config Present)
000058: *Jul 27 11:40:00.681: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
000059: *Jul 27 11:40:00.681: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
000060: *Jul 27 11:40:01.488: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named CISCO_IDEVID_SUDI has been generated or imported by pki-sudi
000061: *Jul 27 11:40:01.514: %PKI-2-NON_AUTHORITATIVE_CLOCK: PKI functions can not be initialized until an authoritative time source, like NTP, can be obtained.
000062: *Jul 27 11:40:02.901: %HA_EM-3-FMPD_UNKNOWN_ENV: fh_parse_var: could not find environment variable: ace
000063: *Jul 27 11:40:02.902: %HA_EM-3-FMPD_ERROR: Error executing applet DynACL statement 1.5
000064: *Jul 27 11:40:02.902: %HA_EM-3-FMPD_ERROR: Error executing applet DynACL statement 1.5
000065: *Jul 27 11:40:19.354: %NETCLK-6-SEL_CLOCK_SRC: Synchronization source Internal is selected by selection process(T0) to synchronize the system and generate T0 output.
000066: *Jul 27 11:40:19.354: %NETCLK-6-ENTER_HOLDOVER: System Internal synchronization source is selected.
000067: *Jul 27 11:40:24.877: %SPA_OIR-6-ONLINECARD: SPA (PVDM4-128) online in subslot 0/4
000068: *Jul 27 11:40:24.934: %DSPRM-5-UP_DOWN: DSP 1 in subslot 0/4, changed state to up
000069: *Jul 27 11:40:24.935: %DSPRM-5-UP_DOWN: DSP 2 in subslot 0/4, changed state to up
000070: *Jul 27 11:40:27.078: ***********************************************************
Detailed call stats collection has been turned on
Use "media disable-detailed-stats" under "voice service voip"to turn it off
000071: *Jul 27 11:40:29.064: %LINK-3-UPDOWN: Interface Service-Engine0/4/0, changed state to up
000072: *Jul 27 11:40:30.064: %LINEPROTO-5-UPDOWN: Line protocol on Interface Service-Engine0/4/0, changed state to up
000073: *Jul 27 11:41:04.175: %SPA_OIR-6-ONLINECARD: SPA (NIM-VA-B) online in subslot 0/2
000074: *Jul 27 11:41:06.164: %LINK-3-UPDOWN: Interface Ethernet0/2/0, changed state to down
000075: *Jul 27 11:41:06.167: %LINK-3-UPDOWN: Interface ATM0/2/0, changed state to down
000076: *Jul 27 11:41:46.690: new extended attributes received from iomd(slot 0 bay 1 board 1)
000077: *Jul 27 11:41:47.951: %SPA_OIR-6-ONLINECARD: SPA (NIM-4MFT-T1/E1) online in subslot 0/1
000078: *Jul 27 11:41:47.956: %IOSXE_OIR-6-SOFT_RELOADSPA: SPA(NIM-4MFT-T1/E1) reloaded on subslot 0/1
000079: *Jul 27 11:41:47.957: %SPA_OIR-6-OFFLINECARD: SPA (NIM-4MFT-T1/E1) offline in subslot 0/1
000080: *Jul 27 11:43:46.040: %SPA_OIR-6-ONLINECARD: SPA (NIM-4MFT-T1/E1) online in subslot 0/1
000081: *Jul 27 11:43:46.102: %DSPRM-5-UP_DOWN: DSP 1 in subslot 0/1, changed state to up
000082: *Jul 27 11:43:46.102: %DSPRM-5-UP_DOWN: DSP 2 in subslot 0/1, changed state to up
000083: *Jul 27 11:43:52.480: %LINK-3-UPDOWN: Interface Service-Engine0/1/0, changed state to up
000084: *Jul 27 11:43:53.481: %LINEPROTO-5-UPDOWN: Line protocol on Interface Service-Engine0/1/0, changed state to up
Router con0 is now available
Press RETURN to get started.
colcha
Beginner
Beginner
XL-Template#sh version
Cisco IOS XE Software, Version 16.09.04
Cisco IOS-XE software, Copyright (c) 2005-2019 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
XL-Template uptime is 11 minutes
Uptime for this control processor is 13 minutes
System returned to ROM by PowerOn at 12:42:41 CET Fri Jan 27 2023
System image file is "bootflash:isr4300-universalk9.16.09.04.SPA.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None None None
securityk9
appxk9
AdvUCSuiteK9 None None None
uck9
cme-srst
cube
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 None None None
uck9 uck9 EvalRightToUse uck9
securityk9 securityk9 RightToUse securityk9
ipbase ipbasek9 None ipbasek9
The current throughput level is 100000 kbps
Smart Licensing Status: Smart Licensing is DISABLED
Processor board ID FDO26XXXXX
1 ATM interface
XL-Template#
colcha
Beginner
Beginner
XL-Template#show license
Index 1 Feature: appxk9
Period left: Not Activated
Period Used: 0 minute 0 second
License Type: EvalRightToUse
License State: Active, Not in Use, EULA not accepted
License Count: Non-Counted
License Priority: None
Index 2 Feature: uck9
Period left: 8 weeks 3 days
Period Used: 14 minutes 23 seconds
License State: Active, In Use
License Priority: Low
Index 3 Feature: securityk9
Period left: Life time
License Type: RightToUse
Index 4 Feature: ipbasek9
Index 5 Feature: FoundationSuiteK9
Index 6 Feature: AdvUCSuiteK9
Index 7 Feature: cme-srst
Period left: 8 weeks 4 days
License State: Active, Not in Use, EULA accepted
License Count: 0/0 (In-use/Violation)
Index 8 Feature: hseck9
Index 9 Feature: throughput
Index 10 Feature: internal_service
XL-Template#
colcha
Beginner
Beginner
XL-Template#show license all
License Store: Primary License Storage
License Store: Built-In License Storage
StoreIndex: 0 Feature: appxk9 Version: 1.0
Evaluation total period: 8 weeks 4 days
Evaluation period left: 8 weeks 4 days
Period used: 0 minute 0 second
StoreIndex: 1 Feature: uck9 Version: 1.0
Evaluation period left: 8 weeks 3 days
Period used: 16 minutes 24 seconds
Transition date: Sep 25 2023 13:39:30
StoreIndex: 2 Feature: securityk9 Version: 1.0
StoreIndex: 3 Feature: FoundationSuiteK9 Version: 1.0
StoreIndex: 4 Feature: AdvUCSuiteK9 Version: 1.0
StoreIndex: 5 Feature: cme-srst Version: 1.0
StoreIndex: 6 Feature: throughput Version: 1.0
XL-Template#
colcha
Beginner
Beginner
the routers that we activate in the client's network always have these licenses activated
colcha
Beginner
Beginner
Hello  M02@rt37
I have problem with license
Technology  Technology-package    Technology-package     Current Type Next reboot
this license The license always appears with the status "EvalRightToUse" / "RightToUse"   :S
The license should appear with this information "Permanent", so I could tell that the license is correct.
Example :
Best regards,
Colcha
Vamos a comenzar
