el 08-23-2023 05:43 PM
Hello team, we purchased a NCS5011.
Has 100gb interfaces, but I put a CVR-QSFP-SFP10G adapter, which works on other equipment.
I configured an interface Te0/0/0/15.
when connecting sfp, it detects everything correctly but doesn´t link.
I tried several things but link turns on for a few seconds and turns off, but no errors are seen in the logs or anywhere.
Label : 7.9.2
cisco NCS-5011 () processor
RP/0/RP0/CPU0:Aug 23 19:35:37.844 CDT: optics_driver[426]: %L2-OPTICS-2-TRANSCEIVER_REMOVED : Optics module TenGigE0/0/0/12 type SFP+ 10G SR serial number AVA1734AXPZ removed
RP/0/RP0/CPU0:Aug 23 19:35:37.848 CDT: ifmgr[345]: %PKT_INFRA-LINK-5-CHANGED : Interface Optics0/0/0/12, changed state to Down
RP/0/RP0/CPU0:Aug 23 19:35:39.266 CDT: ifmgr[345]: %PKT_INFRA-LINK-3-UPDOWN : Interface TenGigE0/0/0/12, changed state to Up
RP/0/RP0/CPU0:Aug 23 19:35:39.267 CDT: ifmgr[345]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface TenGigE0/0/0/12, changed state to Up
RP/0/RP0/CPU0:Aug 23 19:35:41.470 CDT: ifmgr[345]: %PKT_INFRA-LINK-3-UPDOWN : Interface TenGigE0/0/0/12, changed state to Down
RP/0/RP0/CPU0:Aug 23 19:35:41.470 CDT: ifmgr[345]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface TenGigE0/0/0/12, changed state to Down
RP/0/RP0/CPU0:Aug 23 19:35:44.562 CDT: optics_driver[426]: %L2-OPTICS-6-TRANSCEIVER_INSERTED : Optics module TenGigE0/0/0/12 type SFP+ 10G SR serial number AVA1734AXPZ inserted
RP/0/RP0/CPU0:Aug 23 19:35:44.752 CDT: ifmgr[345]: %PKT_INFRA-LINK-5-CHANGED : Interface Optics0/0/0/12, changed state to Up
show controllers optics 0/0/0/12
Wed Aug 23 19:36:21.930 CDT
Controller State: Up
Transport Admin State: In Service
Laser State: Off
LED State: Yellow
Optics Status
Optics Type: SFP+ 10G SR
Wavelength = 850.00 nm
Alarm Status:
Detected Alarms: None
LOS/LOL/Fault Status:
Laser Bias Current = 0.0 mA
Actual TX Power = -40.00 dBm
RX Power = -40.00 dBm
Performance Monitoring: Disable
THRESHOLD VALUES
Parameter High Alarm Low Alarm High Warning Low Warning
Rx Power Threshold(dBm) -40.0 -40.0 -40.0 -40.0
Tx Power Threshold(dBm) -40.0 -40.0 -40.0 -40.0
LBC Threshold(mA) 0.00 0.00 0.00 0.00
Temp. Threshold(celsius) 0.00 0.00 0.00 0.00
Voltage Threshold(volt) 0.00 0.00 0.00 0.00
Polarization parameters not supported by optics
Temperature = 0.00 Celsius
Voltage = 0.00 V
Transceiver Vendor Details
Form Factor : SFP+
Optics type : SFP+ 10G SR
OUI Number : 00.17.6a
Part Number : SFBR-709SMZ-CS1
Rev Number : G4.1
Serial Number : AVA1734AXPZ
PID : SFBR-709SMZ-CS1
VID : G4.1
Date Code(yy/mm/dd) : 13/08/24
please help
thank you!
el 08-23-2023 07:00 PM
I do not see either CVR-QSFP-SFP10G or 10GBASE-SR SFP+ as being supported in the NCS 5011’s data sheet (Table 4).
You might confirm with TAC or your account team that these are supported in the 5011.
Descubra y salve sus notas favoritas. Vuelva a encontrar las respuestas de los expertos, guías paso a paso, temas recientes y mucho más.
¿Es nuevo por aquí? Empiece con estos tips. Cómo usar la comunidad Guía para nuevos miembros
Navegue y encuentre contenido personalizado de la comunidad
