cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Mode rommon
emanuell1613
I have this problem, I don't how to solve this, any can helpe me please
I try this but didn't solve the problem
2 RESPUESTAS 2
Hi @emanuell1613
 Where is written "ruta-y-nomber-del-archivo" should be the actuall file name as in
flash:<ios>
Please, run the command dir flash:  and share the output.
balaji.bandi
what is the model of device and what IOS code was running before ?
issue below command - see if you can see the file ?
switch: flash_init
switch: load_helper
switch: dir flash:/
based on the output
boot flash:image.bin (image.bin replace with bin file output)switch:dir
If this is install mode
boot flash:packages.conf
BB
