cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
PROBLEM JOIN AP 2800I WITH EXPRESS MOBILITY AP
Modelo del WLC : Aironet 2800 Series
Versión del WLC : 8.10.105.0
hello i have a issues with join ap 2800i express mobility with ap 2800i that working with WLC but 3 APs no join. only join 4 APs. totaly APs 7
[*01/08/2019 12:02:18.9774]
[*01/08/2019 12:02:18.9774] CAPWAP State: Discovery
[*01/08/2019 12:02:18.9793] Discovery Request sent to 10.90.100.1, discovery type STATIC_CONFIG(1)
[*01/08/2019 12:02:18.9794] IP DNS query for CISCO-CAPWAP-CONTROLLER.simanindustrial.com
[*01/08/2019 12:02:18.9812] Discovery Request sent to 10.90.100.1, discovery type STATIC_CONFIG(1)
[*01/08/2019 12:02:18.9844] Discovery Request sent to 192.168.3.40, discovery type DNS(3)
[*01/08/2019 12:02:18.9858] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*01/08/2019 12:02:18.9859] Discovery Response from 10.90.100.1
[*01/08/2019 12:02:18.9937] Discovery Response from 10.90.100.1
[*01/08/2019 12:02:19.0011] Discovery Response from 10.90.100.1
3 RESPUESTAS 3
[*01/08/2019 12:01:17.0000] CAPWAP State: DTLS Setup
[*01/08/2019 12:01:17.3601] dtls_process_packet: DTLS Error: 1046
[*01/08/2019 12:01:17.3601] dtls_process_packet: The controller shut down the DTLS connection.
[*01/08/2019 12:01:17.3601] dtls_process_packet: Please verify that the AP certificate is valid and has not expired.
[*01/08/2019 12:02:14.0165] dtls_disconnect: ERROR shutting down dtls connection ...
Julio E. Moisa
Hola
Revisa que tengan el mismo version de sistema operativo, y que les este llegando direccion IP via DHCP.
Saludos.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hi @Rafael Mauricio Navarrete Echegoyen
You can not have in the same network Mobility Express AP with a WLC. You need to choose one of them for managing the network.
Espero que la información haya sido útil y si no tienes más preguntas recuerda cerrar el topic, seleccionando la respuesta como "Respuesta correcta"
**Please rate the answer if this information was useful***
**Por favor si la información fue util marca esta respuesta como correcta**
*Tu reconocimiento nos alienta a seguir participando en los foros *
