cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
ASR1001-X
Hello
I have a device ASR1001-X and I need to know the power consupmtion of the system. In others plataforms, such as ASR9000 this information is breakdown even per component. i.e  consumption per RSP, LC, FC and FANs.
Does anyone know some similar to share?
Thanks you
1 RESPUESTA 1
This is the information displayed on the Cisco page
Power consumption
  • Maximum DC: 1700W
  • Maximum AC: 1600W
  • Maximum (Out): 1275W
reference: https://www.cisco.com/c/en/us/td/docs/routers/asr1000/install/guide/1001-x/asr1hig-book/router_spec.html
Other link: https://www.cisco.com/c/en/us/td/docs/routers/asr1000/install/guide/1001-x/asr1hig-book.pdf
The information per part could be difficult to find unless you search the part models and check the specs.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
