cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
8
Respuestas
Choosing the predetermined path
demon_ir80
Hi.
I have encountered a problem, and I would appreciate it if you could tell me what to do. According to the diagram, we have two PCs, and I want each of them, if they want to ping routers RA4 and Router5, to take different paths.
It means PC 0 wants to ping the router with IP 172.16.1.3 and send the packet to Router RA2.
And similarly, PC 0 wants to ping 172.16.1.4, but this time, only send the packet to RA3.
The routing protocol on the routers is OSPF, and it's active in Area 0.
The Layer 3 switch also has an active VLAN that connects the routers RA2-4, and OSPF is active on them as well.
2 SOLUCIONES ACEPTADAS
Soluciones aceptadas
can you use different process or you must use one OSPF process ?
Thanks A Lot
MHM
Ver la solución en mensaje original publicado
M02@rt37
Hello @demon_ir80,
To achieve different paths for PC0 to ping routers RA4 and RA5, you can use policy-based routing 'PBR' on the Layer 3 switch that connects the PCs and routers.
For PC0 to ping Router RA4 (172.16.1.4) via Router RA2:
ip access-list extended PC0-RA4
permit ip host PC0-IP host 172.16.1.4
route-map PBR-RA4 permit 10
match ip address PC0-RA4
set ip next-hop Router-RA2-IP
interface VLANX # The VLAN interface connecting PC0
ip policy route-map PBR-RA4
For PC0 to ping Router RA5 (172.16.1.3) via Router RA3:
ip access-list extended PC0-RA5
permit ip host PC0-IP host 172.16.1.3
route-map PBR-RA5 permit 10
match ip address PC0-RA5
set ip next-hop Router-RA3-IP
ip policy route-map PBR-RA5
--This configuration will direct traffic from PC0 to the desired routers based on the destination IP address, allowing you to achieve different paths for pinging RA4 and RA5.
Best regards
8 RESPUESTAS 8
Thanks A Lot
MHM
just ospf
M02@rt37
Hello @demon_ir80,
Best regards
can you fix That?
Hola
Hasta donde se, en PT no se puede configurar PBR.
Lo que solicitas se puede lograr en PT configurando rutas estáticas a las IP de destino que indicas, apuntando como siguiente salto a los router  para el camino deseado.
RA1(config)#ip route 172.16.1.3 255.255.255.255 192.168.1.2
RA1(config)#ip route 172.16.1.4 255.255.255.255 192.168.2.2
Con eso los paquetes tomaran el camino deseado.(esto sucede porque las rutas estáticas tienen un AD menor a OSPF y son elegidos como mejor camino en la tabla de ruteo).
Espero que esto te sea de utilidad.
Saludos
Hi, thanks for the help
What if I want to implement inside EVE-NG?Does eve-ng support?
Because in that environment, I RUN the router's own IOS
Ty
Hola
Claro, en EVE-NG o en GNS3 se puede lograr configurar PBR, pues los dispositivos corren el IOS completo, no el IOS emulado de Packet Tracer.
Saludos
Hello @demon_ir80
Thanks for sharing your PT project.
Like I suggest to you in private, PBR is not available on PT ; PT has limitations in the IOS of the devices.
On RA1, route /32 (host) directly  to the desired next-hop:
Best regards
