cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Configurar señalizacion SUA SS7 en un Gateway
gabregu
Buenas
     Soy nuevo en esta tecnología y necesito configurar conectividad SUA entre un ITP  y un  STP.
Seguí las guias: http://www.cisco.com/en/US/docs/wireless/itp/itp_12_2_18_ipx/PDFs/12415sw5.pdf
Pero no levanta, sigo sin poder establecer comunicacion SUA.
DESDE YA MUCHAS GRACIAS!!
Los parametros son los siguientes:
IOS: c2800nm-itpk9-mz.124-15.SW6.bin
ITP#sh run
hostname ITP
no ip cef
no ip domain lookup
ip domain name XXXXXX
cs7 variant ITU
cs7 point-code 4.65.4
cs7 national-options multiple-congestion
cs7 national-options TFR
cs7 sua-allow-xudt-request
cs7 log gtt size 5000
interface FastEthernet0/0
ip address 10.10.10.3 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 100.100.100.129 255.255.255.0
duplex full
speed 100
hold-queue 200 in
cs7 local-peer 7000
local-ip 100.100.100.129
cs7 route-table system
cs7 sua 2905
cs7 asp asp_194_3 2905 2905 sua
remote-ip 100.100.100.18
cs7 as as_3 sua
routing-key 1 4.65.5 si sccp ssn 6
asp asp_194_3 weight 1
cs7 mapua GetIMSI smpp 9000
client 100.100.100.18
client dynamic
smpp response-timer 6000
smpp session-init-timer 3000
get-imsi include-msc
cs7 mapua GetMSRN smpp 9001
shutdown
invoke-timer 15
smpp response-timer 2000
get-msrn map-version 2
sh cs7 sua
SUA  Local port:  2905        State: active      SCTP instance handle: 2905
Local ip address:                                100.100.100.129
Number of active SUA  peers:                     0
Max number of inbound streams allowed:           17
Local receive window:                            64000
Max init retransmissions:                        8
Max init timeout:                                3000 ms
Unordered priority:                              equal
Offload to linecard:                             No     Slot: -1
SCTP defaults for new associations
Transmit queue depth:   1000           Cumulative sack timeout:   200 ms
Assoc retransmissions:  10             Path retransmissions:      4
Minimum RTO:            1000  ms       Maximum RTO:               1000  ms
Bundle status:          on             Bundle timeout:            5 ms
Keep alive status:      true           Keep alive timeout:        30000 ms
Initial cwnd:           3000           Idle cwnd rate:            50
Retrans cwnd rate:      50             Retrans cwnd mode :        RFC
FastRetrans cwnd rate:  50             SCTP RFC Version:          2960
Cookie Life:            5000           Sack-Frequency:            2
ITP#sh cs7 asp
                                                     Effect Primary
ASP Name      AS Name       State     Type  Rmt Port Remote IP Addr  SCTP
asp_194_3     as_3          down      SUA   2905     100.100.100.18
ITP#sh cs7 as
                    Routing    Routing Key                          Cic   Cic
AS Name      State  Context    Dpc           Si   Opc           Ssn Min   Max
as_3         down   1          4.65.5        sccp               6
Informacion adicional.
Parametros del ITP
4.65.4
OPC: 8717
LSS:8
SUA SSN:6
Variante: itu-n
SIO:83
RK_id:1
Prioridad:1
Puerto 2905
IP 100.100.100.129
Parametros del STP
4.65.5
OPC: 8718
Puerto 2905
IP 100.100.100.18
0 RESPUESTAS 0
